outputformat and default image format output
    Kralidis,Tom [Burlington]
    Tom.Kralidis at EC.GC.CA
    Wed Nov 17 09:33:56 PST 2004
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Wednesday, 17 November, 2004 12:27
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] outputformat and default
> image format output
> Kralidis,Tom [Burlington] wrote:
> > Hi,
> > In my mapfile, I've defined:
> >  OUTPUTFORMAT
> >   NAME GEOTIFF_RGB
> >   DRIVER "GDAL/GTiff"
> >   MIMETYPE "image/tiff"
> >   IMAGEMODE RGB
> >   EXTENSION "tif"
> >  END
> > ...for some raster data, which is fine.  However, it seems to have
> > taken over my app/service as the default format.  i.e. if I request:
> > http://host/url?mode=legend&layers=roadlayer
> > ..this gives me back a prompt to download a TIFF image.
> > If I comment out the OUTPUTFORMAT object, I get back a GIF image,
> > which is web friendly.
> > Any ideas on how to define OUTPUTFORMAT and making sure a
> web friendly
> > format is returned on requests?
> Tom,
> Use the IMAGETYPE keyword in the map object to select the
> default format. If you don't the first user defined
> outputformat is used by default.  If there are no user
> defined output formats, the first built-in format will be used.
> So adding "IMAGETYPE GIF" should do the trick.
Works (I used PNG) -- thx.
> Of course, I think all web browsers should have built-in
> GeoTIFF support but I may have a biased point of view.
I second that motion.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
More information about the MapServer-users
