Postgis nquery returns the same result multiple times
Ken Lord
kenlord at GMAIL.COM
Wed Nov 17 13:58:44 EST 2004
Hi James,
I think it is just a pesky syntax problem.
Here's two DATA strings I use that may be of help.
This example is the standard data string I use to draw all features in a table.
DATA "the_geom from (select * from bh_tp_p) as foo using unique gid
using SRID=2"
This one, similar to yours, makes MapServer draw Only the features
that pass the test. (In this case, draw only the drill holes that fall
within a specific mineral claim)
DATA "the_geom from (select * from bh_tp_p where
within(bh_tp_p.the_geom,( select the_geom from mineral_tenure_a where
mineral_tenure_a.claim='ML-5518' ))=true ) as foo using unique gid
using SRID=2"
In this case I had to include the ' =true ' term ... draw the features
where the 'within' test returns true, a detail that took awhile for me
to get right.
You may want to simplify your query by using the ' * ' wildcard, the
specific fields you need will still be in the recordset returned.
Or, maybe there's a conflict where you define the alias ' place.gid AS
gid ' but carry on to use the terms ' place.gid ' instead of its
alias.
Or maybe there's a conflict by testing ' WHERE place.gid=9 ', and then
using the term ' USING UNIQUE place.gid ' instead of using the term '
USING UNIQUE gid '
Anyways, there's a couple ideas for you, good luck!
Ken Lord
On Wed, 17 Nov 2004 11:26:47 -0600, James Martin <martin426 at yahoo.com> wrote:
> Hello,
> I'm trying to perform a nquery on a postgis layer and am recieving a weird
> result. If my DATA = "the_geom from place" the query works fine. However,
> when trying:
> (SELECT place.the_geom AS the_geom,
> place.gid AS gid,
> place.name AS name
> FROM place
> WHERE place.gid=9)
> AS foo USING UNIQUE place.gid
> USING SRID=-1"
> And then bound a point with &imgbox the query returns the correct record,
> but returns it 'N' times, where N is the number of rows in the table. The
> map itself shows only the one point specified in the WHERE clause. If I
> remove the WHERE clause so I can see the other points and bound two of them,
> the query returns the first record 2 * N times.
> If I do just a query with &imgxy it returns just the one result.
> Any help is greatly appreciated!
> -James
Ken Lord B.Sc., A.Dipl.T.H.
Burnaby BC, V5E 4L1
kenlord (at) gmail.com
klord (at) bgcengineering.com
