wrong in extensions
Sandeep Bashyal
gis at UNDPHAIS.ORG.NP
Thu Nov 18 01:46:11 EST 2004
On Wed, 17 Nov 2004 16:09:56 +0200, temiz <temiz at DEPREM.GOV.TR> wrote:
> hello
> my extent in map file:
> EXTENT 419630 4510820 516250 4617510
> my unzoomed -initial extent in php file gives:
> Array ( [0] => 414562.225 [1] => 4510820 [2] => 521317.775 [3] => 4617510 )
> could you possibly tell me why x values are different, but y are same ?
> how can I make correction on x values ?
> should x values in array same as in map file EXTENT ?
> kind regards
> Ahmet Temiz
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Mapserver adjusts the extents (either x or y) given in the mapfile to fit the image size that you specify in the map file. If you want the extents you get from $map->extent and the extent you set in the map file (for whatsoever reason) just change the extent in your map file to what you get from $map->extent.
Regards.
Sandeep Bashyal
National GIS Officer
Humanitarian Assistance Information System (HAIS)
United Nations (NEP/01/008)
UN House, Pulchowk
G.P.O. Box 107
Kathmandu, Nepal
Tel: (+977) 01 5543957
(+977) 01 5554304
Cell:(+977) 9841270854
Fax: (+977) 01 5528059
mailto:gis at undphais.org.np
mailto:sandeep at earthmapping.com
http://www.un.org.np/
