jBox Java applet
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Nov 18 14:36:16 EST 2004
Looks like there are problems with your codebase and archive
parameters. You have:
codebase="java\jBox"
archive="jBoxPNG.jar,png.jar"
The way you have codebase, the 'java' directory will not be found. I
assume that 'mapserver' is an IIS virtual directory, so try:
'codebase=/mapserver/java/jbox'
Forward slashes, not back slashes, as this is a URI, not a DOS path.
I'm a little unclear on the specification of two jar files in the
archive parameter. Is that legal? Where'd you come up with that? And
you have the .jar files in /mapserver/java/jbox/ not a subdirectory,
right?
You might want to start with GIFs and the standard jBox, rather than
jBoxPNG which requries the sixlegs library. If you're using the Sun
Java VM, you don't need six-legs anyway.
I am cc'ing the mapserver-users list as others may spot something that I missed.
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
On Thu, 18 Nov 2004 09:49:02 -0500, Andhare, Manjiri
<mandhare at state.pa.us> wrote:
> Yes I have JVM and after running the demo, if I check the java console,
> I get following:
> load: class jBoxPNG.class not found.
> java.lang.ClassNotFoundException: jBoxPNG.class
> at sun.applet.AppletClassLoader.findClass(Unknown Source)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at sun.applet.AppletClassLoader.loadClass(Unknown Source)
> at sun.applet.AppletClassLoader.loadCode(Unknown Source)
> at sun.applet.AppletPanel.createApplet(Unknown Source)
> at sun.plugin.AppletViewer.createApplet(Unknown Source)
> at sun.applet.AppletPanel.runLoader(Unknown Source)
> at sun.applet.AppletPanel.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
> Caused by: java.io.IOException: open HTTP connection failed.
> at sun.applet.AppletClassLoader.getBytes(Unknown Source)
> at sun.applet.AppletClassLoader.access$100(Unknown Source)
> at sun.applet.AppletClassLoader$1.run(Unknown Source)
> at java.security.AccessController.doPrivileged(Native Method)
> ... 10 more
> Manjiri Andahre
> GIS co-ordinator
> PA Fish & Boat commission
> tel: (814)3595182
> fax:(814)3595153
> -----Original Message-----
> From: Richard Greenwood [mailto:richard.greenwood at gmail.com]
> Sent: Thursday, November 18, 2004 9:43 AM
> To: Manjiri Andhare
> Subject: Re: [UMN_MAPSERVER-USERS] jBox Java applet
> Do you have a Java Virtual machine installed?
> Get one here:
> http://www.java.com/en/download/installed.jsp
> Rich
> Richard Greenwood
> On Thu, 18 Nov 2004 07:29:16 -0600, Manjiri Andhare
> > Hi!
> > I was looking for the functionality to draw a rectangle for zooming in
> on
> > the map. I found jBox by Steve Lime on
> > http://mapserver.gis.umn.edu/contributed.html
> > I have Windows 2000 and I'm running mapserver 4.2 on IIS.
> > I follwed the steps from jBox HOWTO 4.2 to test it with the workshop
> demo.
> > But when i try to run the workshop demo with "Basic application"
> option, in
> > the status bar of Browser(I'm using IE 6.0) I get the message as;
> > Loading Java Applet Failed..
> > And I'm not getting the reason behind this..
> > Here is the changed portion of itasca_basic.html file:
> > <html>
> > <head>
> > <title>MapServer - Itasca Application</title>
> > <script language="javascript">
> > function setbox_handler(name,minx,miny,maxx,maxy)
> > document.mapserv.imgbox.value = minx + " " + miny
> > + " " + maxx + " " + maxy;
> > document.mapserv.imgxy.value = minx + " " + miny;
> > //additional code can go here prior to the form
> > submit, below
> > //for example, form validation code.
> > document.mapserv.submit();
> > function seterror_handler(message)
> > alert(message);
> > </script>
> > </head>
> > <body bgcolor="#ffffff">
> > <center><h1>MapServer - Itasca Application</h1></center>
> > <hr>
> > <form method="GET" action="cgi-bin/mapserv.exe" name="mapserv" >
> > <center>
> > <table border="0" cellspacing="0" cellpadding="4">
> > <tr>
> > <td valign="top" align="center">
> > <table width="390" border="0" cellspacing="0" cellpadding="4"
> > align="center" bgcolor="#666666">
> > <tr>
> > <td colspan="2">
> > <applet
> > code="jBoxPNG.class"
> > width="600"
> > height="600"
> > name="jBox"
> > MAYSCRIPT>
> > <param name="image" value="http:\\[host][img]">
> > </applet>
> > </td>
> > </tr>
> > <tr><td bgcolor="#666666">
> > <img title="scalebar (mi)" alt="scalebar (mi)" src="[scalebar]">
> > </td></tr>
> > </table>
> > </td>
> > <td valign="top" bgcolor="#ffffff">
> > <table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
> > <tr><td>
> > <center><input type="submit" value="Refresh/Query"></center>
> > <p>
> > <input type="radio" name="mode" value="browse" checked>
> <b>Browse
> > map</b><br>
> > <input type="radio" name="mode" value="query"> <b>Query
> > feature</b><br>
> > <input type="radio" name="mode" value="nquery"> <b>Query
> multiple
> > features</b>
> > <hr>
> > <p>
> > <b>Select Layers to Display: </b><br>
> > <select multiple name="layer" size=3>
> > <option value="airports" [airports_select]> Airports
> > <option value="cities" [cities_select]> Cities
> > <option value="lakespy2" [lakespy2_select]> Lakes & Rivers
> > <option value="dlgstln2" [dlgstln2_select]> Streams
> > <option value="roads" [roads_select]> Roads
> > <option value="twprgpy3" [twprgpy3_select]> Townships
> > <option value="drgs" [drgs_select]> USGS 1:250,000 Quads
> > </select>
> > <p>
> > Zoom In <input type=radio name=zoomdir value=1
> [zoomdir_1_check]>
> > Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
> > Zoom Out <input type=radio name=zoomdir value=-1
> [zoomdir_-1_check]>
> > <p>
> > Zoom Size <input type=text name=zoomsize size=4
> value=[zoomsize]>
> > <p>
> > <font size=+1><b>Legend</b></font><br><hr>
> > <img src="[legend]"><hr>
> > <p>
> > <center>
> > <input name="ref" type="image" src="[ref]"
> > border="0"></center>
> > </td></tr></table>
> > </td></tr>
> > </table>
> > </center>
> > <input type="hidden" name="imgbox" value="-1 -1 -1 -1">
> > I have placed the jBox as:
> > c:\Inetpub\wwwroot\MapServer\java\jBox
> > And I have placed the jar files, class files and java source files
> from
> > lib,classes and src folders respectively under
> > If somebody could point out what i'm missing,it'll be great!!
> > Thank you,
> > Manjiri Andhare
> > GIS Coordinator
> > PA Fish & Boat Commission
> > U.S.A.
