Trouble with Projection
Frank Warmerdam
warmerdam at POBOX.COM
Fri Nov 19 09:52:05 EST 2004
Jim Shanton wrote:
> I’m trying to plot a property parcel shp file, and it keeps plotting in
> Pennsylvania instead of North Carolina.
> PROJECTION
> proj=lcc
> lat_0=33.75 #Latitude of False Origin
> lon_0=-79.0 #Longitude of Natural Origin (Central
> Meridian)
> lat_1=34.33333333333334 #Latitude of First Standard Parallel
> lat_2=36.16666666666666
> x_0=2000000.002616666 # False Easting
> y_0=0.0 # False Northing
> ellps=GRS80 # SPHEROID
> a=6378137.0 # from SPHEROID
> ["GRS_1980",6378137,298.257222101]],
> rf=298.257222101 #from SPHEROID
> datum=NAD83
> END
> UNIT["Foot_US",0.3048006096012192]]
Jim,
I think your main problem is the linear units. The default units in
PROJ.4 is meters, but you need US feet. Try adding a "units=us-ft"
in your PROJECTION declaration for the layer. There is also some slight
chance you will need to alter the x_0 parameter by multiplying (or
dividing) by the meter/feet conversion ratio, but I doubt that will
be needed.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
