[UMN_MAPSERVER-USERS] Trouble with Projection - LCC
Ed McNierney
ed at TOPOZONE.COM
Fri Nov 19 09:57:50 EST 2004
Jim / Skweda -
No, in this case you DON'T want to put UNITS METERS in the layer section, because these units are not meters. The PRJ file indicates that this is a State Plane projection with units of US Feet.
UNITS DD in the main MAP file section is a good idea, however - it's not the cause of this problem, but it will prevent other problems in the future.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Skweda O'Bomsawin
Sent: Friday, November 19, 2004 9:51 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] RE : [UMN_MAPSERVER-USERS] Trouble with Projection - LCC
Be sure to put UNITS DD in the map section and UNITS METERS in the layer section since LCC is in meters...
Skweda O'Bomsawin
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Shanton, James A
Envoyé : 19 novembre 2004 09:13
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Trouble with Projection - LCC
I'm trying to plot a property parcel shp file, and it keeps plotting in Pennsylvania instead of North Carolina.
It also prints out the wrong size. (much to big )
I've posted my parcel layer (from the .map file ) and the PRJ file that came with the shp file.
What am I doing wrong ?
My map file output projection is :
PROJECTION
"proj=longlat"
"ellps=WGS84"
END
Thanks !
Jim
LAYER # PARCELS
NAME "parcel"
DATA parcel
STATUS ON
TYPE POLYGON
PROJECTION
proj=lcc
lat_0=33.75 #Latitude of False Origin
lon_0=-79.0 #Longitude of Natural Origin (Central Meridian)
lat_1=34.33333333333334 #Latitude of First Standard Parallel
lat_2=36.16666666666666
x_0=2000000.002616666 # False Easting
y_0=0.0 # False Northing
ellps=GRS80 # SPHEROID
a=6378137.0 # from SPHEROID["GRS_1980",6378137,298.257222101]],
rf=298.257222101 #from SPHEROID["GRS_1980",6378137,298.257222101]],
datum=NAD83
END
CLASS
OUTLINECOLOR 0 0 0
END
END # end of Parcel layer
Here is the PRJ file
PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic"],
PARAMETER["False_Easting",2000000.002616666],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-79.0],
PARAMETER["Standard_Parallel_1",34.33333333333334],
PARAMETER["Standard_Parallel_2",36.16666666666666],
PARAMETER["Latitude_Of_Origin",33.75],
UNIT["Foot_US",0.3048006096012192]]
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.784 / Virus Database: 530 - Release Date: 2004-10-27
Outgoing mail is certified Virus Free.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041119/c19b9a15/attachment.html
