Trouble with Projection - LCC[Scanned]
Shanton, James A James.Shanton2 at NSCORP.COM
Mon Nov 22 01:13:16 PST 2004
-----Original Message-----
Sent: Friday, November 19, 2004 9:13 AM
To: 'mapserver-users at lists.umn.edu'
Subject: Trouble with Projection - LCC
I'm trying to plot a property parcel shp file, and it keeps plotting in
Pennsylvania instead of North Carolina.
It also prints out the wrong size.  (much to big )
I've posted my parcel layer (from the .map file )  and the PRJ file that
came with the shp file.
What am I doing wrong ?
My map file output projection is :
PROJECTION
  "proj=longlat"
  "ellps=WGS84"
END
Thanks !
Jim
LAYER # PARCELS
  NAME "parcel"
  DATA parcel
  STATUS ON
  TYPE POLYGON
  PROJECTION
     proj=lcc
     lat_0=33.75              #Latitude of False Origin
     lon_0=-79.0              #Longitude of Natural Origin (Central
Meridian)
     lat_1=34.33333333333334  #Latitude of First Standard Parallel
     lat_2=36.16666666666666
     x_0=2000000.002616666    # False Easting
     y_0=0.0                  # False Northing
     ellps=GRS80              # SPHEROID
     a=6378137.0              # from
SPHEROID["GRS_1980",6378137,298.257222101]],
     rf=298.257222101         #from
     datum=NAD83
  END
  CLASS
            OUTLINECOLOR 0 0 0
  END
END # end of Parcel layer
Here is the PRJ file
PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic"],
PARAMETER["False_Easting",2000000.002616666],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-79.0],
PARAMETER["Standard_Parallel_1",34.33333333333334],
PARAMETER["Standard_Parallel_2",36.16666666666666],
PARAMETER["Latitude_Of_Origin",33.75],
UNIT["Foot_US",0.3048006096012192]]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041122/8948eda3/attachment.htm>
More information about the MapServer-users mailing list
