WFS Metadata versus connection string (envdat WFS)
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Nov 22 13:59:53 EST 2004
Note sure what the pb is. checking into this ... Tom is it possible to
get your map file ? If not I will check it with test files that I have here.
Kralidis,Tom [Burlington] wrote:
>>Tyler Mitchell wrote:
>>>I'm working with this WFS data:
>>http://map.ns.ec.gc.ca/envdat/map.aspx?service=WFS&version=1.0.0&reque
>>>st=GetCapabilities
>>>It works, but I'm a bit confused when using the data in my
>>map file.
>>>If I put the parameters manually into the connection string/URL, it
>>>works. But if I put parameters like wfs_version,
>>wfs_request into the
>>>metadata section for the layer (and remove them from the URL) it
>>>doesn't seem to work anymore.
>>Are you using 4.2 or 4.4?
>>If you are using 4.4, then wfs_* metadata should be supported
>>(and the old method of passing everything in the CONNECTION
>>string deprecated), but unfortunately the WFS Client HOWTO
>>still hasn't been updated to reflect that. You may find some
>>useful hints in bug 417:
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=417
> Actually, I just tested this again with 4.4.0-beta2, and get the same
> issues Tyler has (parameters embedded in CONNECTION work, parameters as
> METADATA/wfs_* with no parameters in CONNECTION does not).
> When I try this, .gml files are written to my temp directory. Upon
> checking these w.r.t. this issue, they all come back as OGC service
> exceptions, like:
> "VERSION keyword missing"
> ..and so on.
> ..Tom
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
