ok - got zoom to work - another question
Joseph Norris
sirronj at PACBELL.NET
Tue Nov 23 17:15:57 EST 2004
Thanks Eric - so as I understand you:
MAP
NAME CalMap
STATUS ON
EXTENT 5890870.385 -192053.200 8943310.847 3226086.749
IMAGETYPE GIF
SIZE 600 600
SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "map"
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME "cal_zp_st"
TYPE POLYGON
DATA "cal_zp_st"
STATUS DEFAULT
CLASSITEM "ZCTA"
CLASS
EXPRESSION
/94087|90408|94107|95118|94530|74580|95404|93711|94904|92030|94121|91042|961
01|94523|95548|95658|92057|92503/
STYLE
SYMBOL 'circle'
SIZE 2
COLOR 255 102 102
END
END
CLASS
EXPRESSION /./
OUTLINECOLOR 204 204 204
END
END
LAYER
NAME "poly_minscale"
TYPE POLYGON
DATA "cal_zp_st"
STATUS DEFAULT
MINSCALE ????
CLASS
SYMBOL 'circle'
SIZE 2
COLOR 255 102 102
END
END
LAYER
NAME "poly_maxscale"
TYPE POLYGON
DATA "cal_zp_st"
STATUS DEFAULT
MAXSCALE????
I don't know what the class would be if any
END
END # end map from header
How do I determine the minscale and maxscale?
Thanks
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of Eric Bridger
Sent: Monday, November 22, 2004 9:53 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] ok - got zoom to work - another question
At 08:39 AM 11/22/2004 -0800, Joseph Norris wrote:
>Everyone,
>I have my zoom working but now I would like to tackle something else. I am
>putting an ellipse in the zip polygons if there is a 1-more teachers there.
>For each zip there maybe a max of 10 teachers. I would like an ellipse or
>symbol for each one so that when the user zooms into the polygon they can
>see a symbol for each teacher. Can I do this within the class? If so how
or
>would be the best way to handle this?
You can do this in the map file by creating two layers and using MAXSCALE,
MINSCALE.
Layer 1 has one ellipse per zip wherever there are 1-10 teachers.
MINSCALE is set so that it won't appear when you are zoomed in.
Layer 2 has one ellipse for each teacher and has MAXSCALE set so that it
turns on when Layer 1 is turned off.
Of course if you are using Perl Mapscript you will need to calculate the
scale yourself and turn on and off the layers yourself.
Here's and example:
my $current_scale = calculateScale($map, $imgext[0], $imgext[2]);
# From mapserver3.6.4: mapscale.c msCalculateScale(). This is not a
precision thing. We don't worry about
# msAdjustExtent() since in all our maps, image SIZE has same aspect ratio
as the map EXTENT.
# $minx and $maxx are optional in which case the current extent of the map
is used.
# Be careful about the current map's extent. zoomMap() changes the extents.
sub calculateScale{
my ($map, $minx, $maxx) = @_;
if(!$minx){
$minx = $map->{extent}->{minx};
$maxx = $map->{extent}->{maxx};
my @inchesPerUnit = (1, 12, 63360.0, 39.3701, 39370.1, 4374754);
my $width = $map->{width};
my $units = $map->{units}; # index into unitsPerUnit array
my $resolution = $map->{resolution};
my $md = $width / ($resolution * $inchesPerUnit[$units]);
my $gd = $maxx - $minx;
return($gd/$md);
Eric
