going crazy on setting the colors of my zip polygons via perl
mapscript
Manfred Meier
m.meier at SPIEKERMANN.DE
Mon Nov 29 00:01:39 EST 2004
I don't know if that helps, i tried a long time ago something like:
my $c = new mapscript::colorObj(255,0,0);
$class->{styles}->{color} = $c;
This did it for me and when I remember right, the setting with ->{red},
->{green} and ->{blue} didn't work.
Joseph Norris schrieb:
> Come on!!!! Does anyone out there set color with perl/mapscript? I can do a
> class->setExpression("/lkasjdfkj/") - at least I think it is working - no
> errors however I can not set the color so that my map reflects that the
> regex was found? I just know that someone out there has got it to work.
> Please and thanks.
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
> $_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
> Behalf Of Joseph Norris
> Sent: Saturday, November 27, 2004 10:03 PM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: [UMN_MAPSERVER-USERS] going crazy on setting the colors of my zip
> polygons via perl mapscript
> Group,
> I have found several samples of setting the color of a polygon based upon
> class that I come up with this:
> $zip_expression =~ s/\|$//;
> my $class = new mapscript::classObj($layerObj);
> $class->setExpression("/$zip_expression/");
> $class->{styles}->{color}->{red} = 255;
> $class->{styles}->{color}->{green} = 153;
> $class->{styles}->{color}->{blue} = 153;
> $layerObj->draw($map, $img);
> However - this is not working. I am getting the right zip codes but no
> matter what I do I can not get my mapscript to set the color based upon the
> expression. When I was build the map file via perl I could set these just
> fine but now I would like to use the perl->mapscript interface to do this.
> What is wrong with the above snippet?
> Thanks.
