Things are comming along but .... pleaselook at this mapfile
dump
Joseph Norris
sirronj at PACBELL.NET
Mon Nov 29 16:52:48 EST 2004
Steve,
Tried this and it did not make a change. Nothing so far has made a change:
When I put in init=latlong I get an error.
Here is what I have so far:
MAP
EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
TEMPLATEPATTERN "map"
IMAGECOLOR 255 255 255
IMAGETYPE gif
SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
SIZE 600 600
STATUS ON
UNITS FEET
NAME "calmap"
PROJECTION
"init=epsg:26942"
END
OUTPUTFORMAT
NAME gif
MIMETYPE image/gif
DRIVER GD/GIF
EXTENSION gif
IMAGEMODE PC256
TRANSPARENT FALSE
END
SYMBOL
NAME "circle"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION CC
END
POSITION LL
STATUS EMBED
END
WEB
IMAGEPATH ""
IMAGEURL ""
QUERYFORMAT text/html
END
LAYER
CLASSITEM "zcta"
DATA "cal_zp_st"
NAME "calzip"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POLYGON
UNITS FEET
PROJECTION
"init=epsg:26942"
END
CLASS
NAME "Zip Boundries"
EXPRESSION /./
STYLE
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 204 204 204
SIZE 1
END
END
END
LAYER
NAME "points"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TYPE POINT
UNITS FEET
PROJECTION
"proj=latlong"
END
CLASS
NAME "Teacher"
LABEL
SIZE LARGE
TYPE BITMAP
BUFFER 2
COLOR 255 102 102
MINFEATURESIZE AUTO
POSITION AUTO
END
STYLE
COLOR 255 102 102
MAXSIZE 100
MINSIZE 1
OUTLINECOLOR 255 153 51
SIZE 10
SYMBOL "circle"
END
END
FEATURE
POINTS
-121.507 38.5263
END
TEXT "Mary Lyn Kagan"
END
FEATURE
POINTS
-122.451 37.7752
END
TEXT "Greg D'Amico"
END
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Monday, November 29, 2004 1:40 PM
To: Joseph Norris
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Things are comming along but ....
pleaselook at this mapfile dump
Joseph,
For you point layer, it needs the projection set to
PROJECTION
"init=latlong"
END
-Steve W
Joseph Norris wrote:
> Thanks Eric,
> I set the projections as you indicate below in my map and in each layer -
I
> still see now points for the list of features that I have.
chr
> From: Eric Bridger [mailto:eric at gomoos.org]
> Sent: Monday, November 29, 2004 1:25 PM
> To: Joseph Norris
> Cc: UMN MapServerList
> On Mon, 2004-11-29 at 15:26, Joseph Norris wrote:
>>I got the extents from shpdump of shape file. I do have projection
>>information on the file:
>>PROJCS["NAD_1983_StatePlane_California_II_FIPS_0402_Feet",
>>GEOGCS["GCS_North_American_1983",
>>DATUM["D_North_American_1983",
>>SPHEROID["GRS_1980", 6378137, 298.257222101]],
>>PRIMEM["Greenwich", 0],
>>UNIT["Degree", 0.017453292519943295]],
>>PROJECTION["Lambert_Conformal_Conic"],
>>PARAMETER["False_Easting", 6561666.666666666],
>>PARAMETER["False_Northing", 1640416.666666667],
>>PARAMETER["Central_Meridian", -122],
>>PARAMETER["Standard_Parallel_1", 38.33333333333334],
>>PARAMETER["Standard_Parallel_2", 39.83333333333334],
>>PARAMETER["Latitude_Of_Origin", 37.66666666666666],
>>UNIT["Foot_US", 0.30480060960121924]]
> Joseph,
> By looking in my epsg file (which comes with the proj4 install, on my
> freeBSD system: /usr/local/share/proj it looks like your shape file has
> an EPSG code of 26942.(California Zone 2) You can use the following
> PROJECTION:
> PROJECTION
> "init=epsg:26942"
> END
> For UNITS you would use "feet" not DD.
> HTH.
