Things are comming along but .... pleaselook at this mapfile
dump
Joseph Norris
sirronj at PACBELL.NET
Mon Nov 29 17:28:45 EST 2004
I did that Steve - no change. What's really strange is that I know that
mapserver is recognizing my Teacher class because its coming up in the
legend. But no circle symbols are showing up in my map. The features are
not showing.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Monday, November 29, 2004 2:16 PM
To: Joseph Norris
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Things are comming along but ....
pleaselook at this mapfile dump
Joseph,
In layer "points" change UNITS to "UNITS DD"
What is the error you are getting?
-Steve
Joseph Norris wrote:
> Steve,
> Tried this and it did not make a change. Nothing so far has made a
change:
> When I put in init=latlong I get an error.
> Here is what I have so far:
> MAP
> EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
> TEMPLATEPATTERN "map"
> IMAGECOLOR 255 255 255
> IMAGETYPE gif
> SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
> SIZE 600 600
> STATUS ON
> UNITS FEET
> NAME "calmap"
> PROJECTION
> "init=epsg:26942"
> END
> OUTPUTFORMAT
> NAME gif
> MIMETYPE image/gif
> DRIVER GD/GIF
> EXTENSION gif
> IMAGEMODE PC256
> TRANSPARENT FALSE
> END
> SYMBOL
> NAME "circle"
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> POSITION CC
> END
> POSITION LL
> STATUS EMBED
> END
> WEB
> IMAGEPATH ""
> IMAGEURL ""
> QUERYFORMAT text/html
> END
> LAYER
> CLASSITEM "zcta"
> DATA "cal_zp_st"
> NAME "calzip"
> SIZEUNITS PIXELS
> STATUS DEFAULT
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> TYPE POLYGON
> UNITS FEET
> PROJECTION
> "init=epsg:26942"
> END
> CLASS
> NAME "Zip Boundries"
> EXPRESSION /./
> STYLE
> MAXSIZE 100
> MINSIZE 1
> OUTLINECOLOR 204 204 204
> SIZE 1
> END
> END
> END
> LAYER
> NAME "points"
> SIZEUNITS PIXELS
> STATUS DEFAULT
> TOLERANCE 0
> TYPE POINT
> UNITS FEET
> PROJECTION
> "proj=latlong"
> END
> CLASS
> NAME "Teacher"
> LABEL
> SIZE LARGE
> TYPE BITMAP
> BUFFER 2
> COLOR 255 102 102
> MINFEATURESIZE AUTO
> POSITION AUTO
> END
> STYLE
> COLOR 255 102 102
> MAXSIZE 100
> MINSIZE 1
> OUTLINECOLOR 255 153 51
> SIZE 10
> SYMBOL "circle"
> END
> END
> FEATURE
> POINTS
> -121.507 38.5263
> END
> TEXT "Mary Lyn Kagan"
> END
> FEATURE
> POINTS
> -122.451 37.7752
> END
> TEXT "Greg D'Amico"
> END
chr
> Sent: Monday, November 29, 2004 1:40 PM
> To: Joseph Norris
> Joseph,
> For you point layer, it needs the projection set to
> PROJECTION
> "init=latlong"
> END
> -Steve W
>>Thanks Eric,
>>I set the projections as you indicate below in my map and in each layer -
> I
>>still see now points for the list of features that I have.
> chr
>>From: Eric Bridger [mailto:eric at gomoos.org]
>>Sent: Monday, November 29, 2004 1:25 PM
>>To: Joseph Norris
>>Cc: UMN MapServerList
>>On Mon, 2004-11-29 at 15:26, Joseph Norris wrote:
>>>I got the extents from shpdump of shape file. I do have projection
>>>information on the file:
>>>PROJCS["NAD_1983_StatePlane_California_II_FIPS_0402_Feet",
>>>GEOGCS["GCS_North_American_1983",
>>>DATUM["D_North_American_1983",
>>>SPHEROID["GRS_1980", 6378137, 298.257222101]],
>>>PRIMEM["Greenwich", 0],
>>>UNIT["Degree", 0.017453292519943295]],
>>>PROJECTION["Lambert_Conformal_Conic"],
>>>PARAMETER["False_Easting", 6561666.666666666],
>>>PARAMETER["False_Northing", 1640416.666666667],
>>>PARAMETER["Central_Meridian", -122],
>>>PARAMETER["Standard_Parallel_1", 38.33333333333334],
>>>PARAMETER["Standard_Parallel_2", 39.83333333333334],
>>>PARAMETER["Latitude_Of_Origin", 37.66666666666666],
>>>UNIT["Foot_US", 0.30480060960121924]]
>>Joseph,
>>By looking in my epsg file (which comes with the proj4 install, on my
>>freeBSD system: /usr/local/share/proj it looks like your shape file has
>>an EPSG code of 26942.(California Zone 2) You can use the following
>>PROJECTION:
>>PROJECTION
>> "init=epsg:26942"
>>END
>>For UNITS you would use "feet" not DD.
>>HTH.
