gdal above 1.2.3 not building
    Benjamin Thelen
    bt at CCGIS.DE
    Tue Nov 30 11:13:14 PST 2004
Frank Warmerdam wrote:
> On Tue, 30 Nov 2004 19:36:42 +0100, Benjamin Thelen <bt at ccgis.de> wrote:
>>Hi list, hello Frank,
>>I have a SuSE 9.0 with gcc-3.3.1 running and try to install
>>gdal-1.2.5. I receive the following error at the end of ./configure. I
>>suppose, that this is the reason why "make" stops. The same ist true
>>for gdal-1.2.4.
>>configure: creating ./config.status
>>config.status: creating GDALmake.opt
>>sed: file ./confstatuuF913/subs-3.sed line 16: Unterminated `s' command
>>config.status: creating port/cpl_config.h
>>config.status: port/cpl_config.h is unchanged
>>GDAL is now configured for i686-pc-linux-gnu
>>GDALmake.opt is empty!?
>>It is no problem to build gdal-1.2.3 and it is also no problem to
>>build newer versions than 1.2.3 on debian with gcc-2.95.
>>I hope to get Mr.SID support compiled successfully into the newer
>>versions, because this files on 1.2.3 and earlier.
> Benjamin,
> This is a bug with the mysql autoconfiguration logic.
> Just add --without-mysql to the configure line.  This
> should be fixed in CVS though, apparently the fix did
> not make it into the 1.2.5 version.
> Best regards,
Well, thanks Frank, that did help! But now I run into another error.
Something with ogr. Please see below.
--without-ogr worked fine, but I need ogr!
I read something about adding s57featuredefns.o into a makefile, but
that was already there.
Thanks again,
Ben
make[1]: Entering directory `/data/src/gdal-1.2.5/ogr'
/bin/sh ../libtool --mode=compile g++ -Wall  -O2    -Iogrsf_frmts -I.
-I../po
rt -I../gcore -I../ogr -I../alg   -DHAVE_GEOS=1 -I/usr/local/include
-I../por
t  -c -o ogrinfo.o ogrinfo.cpp
  g++ -Wall -O2 -Iogrsf_frmts -I. -I../port -I../gcore -I../ogr
-I../alg -DHAV
E_GEOS=1 -I/usr/local/include -I../port -c ogrinfo.cpp  -fPIC -DPIC -o
.libs/
ogrinfo.o
-I../alg -DHAV
E_GEOS=1 -I/usr/local/include -I../port -c ogrinfo.cpp -o ogrinfo.o
 >/dev/nul
l 2>&1
/bin/sh ../libtool --mode=link  g++  ogrinfo.o ../libgdal.la -o ogrinfo
g++ ogrinfo.o -o .libs/ogrinfo  ../.libs/libgdal.so -L/usr/local/lib
/usr/loc
al/lib/libgeos.so /usr/lib/libjpeg.so -lpng -lz -ldl -L/usr/lib -lpq
/usr/lib
/libstdc++.so
../.libs/libgdal.so: undefined reference to `GDALCopyWords'
`GDALDataset::IRasterIO(GDALRWFla
g, int, int, int, int, void*, int, int, GDALDataType, int, int*, int,
int, in
t)'
../.libs/libgdal.so: undefined reference to `typeinfo for GDALRasterBand'
`GDALMajorObject::SetMetadataItem
(char const*, char const*, char const*)'
../.libs/libgdal.so: undefined reference to `GDALRasterBand::GetDataset()'
`GDALRasterBand::GetRasterDataTyp
e()'
../.libs/libgdal.so: undefined reference to `GDALColorTable::Clone()
const'
`GDALDataset::GetGCPProjection()'
../.libs/libgdal.so: undefined reference to `GDALDataset::Dereference()'
`GDALDataset::IBuildOverviews(cha
r const*, int, int*, int, int*, int (*)(double, char const*, void*),
void*)'
`GDALDataset::GetRasterCount()'
../.libs/libgdal.so: undefined reference to `GDALInitGCPs'
../.libs/libgdal.so: undefined reference to `GDALDestroyScaledProgress'
`GDALMajorObject::GetMetadataItem
(char const*, char const*)'
`GDALRasterBand::GetOverview(int)
`GDALColorTable::GetColorEntryAsR
GB(int, GDALColorEntry*) const'
`GDALDataset::GetRasterXSize()'
`GDALWarpOperation::Initialize(GD
ALWarpOptions const*)'
../.libs/libgdal.so: undefined reference to `GDALDriver::~GDALDriver
[not-in-
charge]()'
`GDALRasterBand::ReadBlock(int, i
nt, void*)'
../.libs/libgdal.so: undefined reference to `GDALDataset::GetGCPCount()'
`GDALRasterBand::~GDALRasterBand
[not-in-charge]()'
`GDALWarpOperation::WarpRegionToB
uffer(int, int, int, int, void*, GDALDataType, int, int, int, int)'
`GDALRasterBand::GetScale(int*)'
../.libs/libgdal.so: undefined reference to `typeinfo for GDALMajorObject'
../.libs/libgdal.so: undefined reference to `GDALGetRasterBandYSize'
../.libs/libgdal.so: undefined reference to `GDALGetGeoTransform'
`GDALDataset::GetRasterYSize()'
`GDALDataset::GetInternalHandle(c
har const*)'
`GDALRasterBand::HasArbitraryOver
views()'
`GDALDataset::SetProjection(char
const*)'
../.libs/libgdal.so: undefined reference to `GDALApproxTransform'
`GDALRasterBand::SetColorInterpre
tation(GDALColorInterp)'
../.libs/libgdal.so: undefined reference to `GDALDataset::GetGCPs()'
`GDALDataset::GDALDataset[not-in-
charge]()'
`GDALMajorObject::~GDALMajorObjec
t [not-in-charge]()'
`GDALWarpOperation::GDALWarpOpera
tion[in-charge]()'
../.libs/libgdal.so: undefined reference to `GDALGetDataTypeSize'
`GDALColorTable::~GDALColorTable
[in-charge]()'
`GDALRasterBand::IsBlockCached(in
t, int)'
`GDALRasterBand::IWriteBlock(int,
  int, void*)'
../.libs/libgdal.so: undefined reference to `GDALGCPsToGeoTransform'
../.libs/libgdal.so: undefined reference to `GDALDataset::~GDALDataset
[not-i
n-charge]()'
../.libs/libgdal.so: undefined reference to `GDALDestroyWarpOptions'
`GDALMajorObject::SetMetadata(cha
r**, char const*)'
`GDALRasterBand::GetUnitType()'
../.libs/libgdal.so: undefined reference to `GDALGetRasterBandXSize'
../.libs/libgdal.so: undefined reference to `GDALDataset::SetGCPs(int,
GDAL_G
CP const*, char const*)'
../.libs/libgdal.so: undefined reference to `GDALRasterBand::GetXSize()'
../.libs/libgdal.so: undefined reference to `GDALDereferenceDataset'
`GDALRasterBand::GetBlockRef(int,
  int, int)'
`GDALColorTable::GetColorEntryCou
nt() const'
../.libs/libgdal.so: undefined reference to `GDALDuplicateGCPs'
`GDALRasterBand::SetColorTable(GD
ALColorTable*)'
`GDALCreateGenImgProjTransformer'
`GDALDriver::GDALDriver[in-charge
../.libs/libgdal.so: undefined reference to `GDALCreateApproxTransformer'
../.libs/libgdal.so: undefined reference to `GDALDriver::Delete(char
const*)'
../.libs/libgdal.so: undefined reference to `GDALSwapWords'
../.libs/libgdal.so: undefined reference to `GDALGetGCPProjection'
../.libs/libgdal.so: undefined reference to `GDALDummyProgress'
../.libs/libgdal.so: undefined reference to `GDALRasterBand::GetAccess()'
`GDALRasterBand::WriteBlock(int,
int, void*)'
`GDALRasterBand::GetCategoryNames
../.libs/libgdal.so: undefined reference to `GDALReadWorldFile'
../.libs/libgdal.so: undefined reference to `GDALRasterBand::GetBand()'
`GDALDefaultOverviews::Initialize
(GDALDataset*, char const*, int)'
`GDALRasterBand::BuildOverviews(c
har const*, int, int*, int (*)(double, char const*, void*), void*)'
`GDALRasterBand::GDALRasterBand[n
ot-in-charge]()'
`GDALMajorObject::GetMetadata(cha
r const*)'
`GDALDataset::BlockBasedRasterIO(
GDALRWFlag, int, int, int, int, void*, int, int, GDALDataType, int,
int*, int
, int, int)'
../.libs/libgdal.so: undefined reference to `GDALRegenerateOverviews'
../.libs/libgdal.so: undefined reference to `GDALRasterBand::GetYSize()'
`GDALMajorObject::SetDescription(
char const*)'
`GDALRasterBand::GetOverviewCount
../.libs/libgdal.so: undefined reference to `GDALRasterIO'
../.libs/libgdal.so: undefined reference to `GDALDataset::Reference()'
../.libs/libgdal.so: undefined reference to `GDALOpen'
`GDALMajorObject::GDALMajorObject
[not-in-charge]()'
../.libs/libgdal.so: undefined reference to `GDALDriver::Create(char
const*,
int, int, int, GDALDataType, char**)'
`GDALDataset::AddBand(GDALDataTyp
e, char**)'
`GDALRasterBand::OverviewRasterIO
(GDALRWFlag, int, int, int, int, void*, int, int, GDALDataType, int, int)'
`GDALWarpOperation::GetOptions()'
../.libs/libgdal.so: undefined reference to `GDALDataset::FlushCache()'
`GDALRasterBand::SetCategoryNames
(char**)'
../.libs/libgdal.so: undefined reference to `GDALDataTypeUnion'
../.libs/libgdal.so: undefined reference to `GDALDataset::GetShared()'
`GDALDataset::GetProjectionRef()'
../.libs/libgdal.so: undefined reference to `GDALGetRasterBand'
`GDALRasterBand::SetNoDataValue(d
ouble)'
../.libs/libgdal.so: undefined reference to `GDALSerializeWarpOptions'
../.libs/libgdal.so: undefined reference to `GDALCreateScaledProgress'
../.libs/libgdal.so: undefined reference to `GDALReprojectImage'
../.libs/libgdal.so: undefined reference to `GDALSetProjection'
../.libs/libgdal.so: undefined reference to `GDALWriteWorldFile'
../.libs/libgdal.so: undefined reference to `typeinfo for GDALDataset'
../.libs/libgdal.so: undefined reference to `GDALCreateWarpOptions'
../.libs/libgdal.so: undefined reference to `GDALScaledProgress'
`GDALDriver::GDALDriver[not-in-ch
arge]()'
../.libs/libgdal.so: undefined reference to `GDALDeinitGCPs'
../.libs/libgdal.so: undefined reference to `GDALCloneWarpOptions'
../.libs/libgdal.so: undefined reference to `GDALDataset::GetDriver()'
`GDALSetGenImgProjTransformerDstG
eoTransform'
`GDALRasterBand::IRasterIO(GDALRW
`GDALDataset::RasterInitialize(in
t, int)'
`GDALRasterBand::GetColorInterpre
tation()'
../.libs/libgdal.so: undefined reference to `GDALGetRasterCount'
../.libs/libgdal.so: undefined reference to `GDALReferenceDataset'
`GDALRasterBand::GetOffset(int*)'
../.libs/libgdal.so: undefined reference to `GDALGetProjectionRef'
../.libs/libgdal.so: undefined reference to `GDALVersionInfo'
`GDALDataset::RasterIO(GDALRWFlag
int, int
`GDALDataset::GetGeoTransform(dou
ble*)'
`GDALRasterBand::GetNoDataValue(i
nt*)'
`GDALRasterBand::RasterIO(GDALRWF
../.libs/libgdal.so: undefined reference to `GDALGetGCPCount'
`GDALDataset::GetRasterBand(int)'
`GDALDataset::SetGeoTransform(dou
ble*)'
`GDALGetColorInterpretationName'
`GDALRasterBand::GetColorTable()'
../.libs/libgdal.so: undefined reference to `GDALOpenShared'
../.libs/libgdal.so: undefined reference to `GDALDataset::SetBand(int,
GDALRa
sterBand*)'
`GDALMajorObject::GetDescription(
) const'
../.libs/libgdal.so: undefined reference to `GDALGetDataTypeName'
../.libs/libgdal.so: undefined reference to `GDALDeserializeWarpOptions'
`GDALDataset::BuildOverviews(char
void*)'
`GDALColorTable::GDALColorTable[i
n-charge](GDALPaletteInterp)'
`GDALColorTable::SetColorEntry(in
t, GDALColorEntry const*)'
../.libs/libgdal.so: undefined reference to `GDALSuggestedWarpOutput'
../.libs/libgdal.so: undefined reference to `GDALGetBandDataset'
../.libs/libgdal.so: undefined reference to `typeinfo for GDALDriver'
`GDALRasterBand::GetMaximum(int*)
`GDALRasterBand::GetBlockSize(int
*, int*)'
../.libs/libgdal.so: undefined reference to `GDALDataTypeIsComplex'
`GDALRasterBand::Fill(double, dou
ble)'
../.libs/libgdal.so: undefined reference to `GDALGenImgProjTransform'
../.libs/libgdal.so: undefined reference to `GDALClose'
../.libs/libgdal.so: undefined reference to `GDALReadTabFile'
`GDALRasterBand::GetMinimum(int*)
../.libs/libgdal.so: undefined reference to `GDALRasterBand::FlushCache()'
collect2: ld returned 1 exit status
make[1]: *** [ogrinfo] Error 1
make[1]: Leaving directory `/data/src/gdal-1.2.5/ogr'
make: *** [ogr-apps] Error 2
More information about the MapServer-users
