Premature end of script headers
Hans de Bruin
maplist at AVIATION.NL
Tue Nov 30 14:44:27 EST 2004
Did you by chance add any GRID layers ? I had this when I was zoomed out
too much with a
GRID layer active. Eventually the server (win2k) gave up with a 'not enough
virtual memory' message.
Hans
At 14:22 30/11/2004 -0500, Morin, Marc-André wrote:
>Hi folks,
>I made a mapfile with over 20 layers (polygons and polylines)... At the
>beginning, all was working fine!
>After having added some other layers, I now seem to get an out of memory
>error.
>Actually, after some clicks (zoom in, zoom out or pan) in the view, I get an
>internal server error.
>Here is what I extracted from the error.log file:
>[error] [client 127.0.0.1] Premature end of script headers: mapserv.exe,
>referer: a certain url...
>and from access.log:
>127.0.0.1 - - [30/Nov/2004:13:46:22 -0500] "GET ...the same url... HTTP/1.1"
>500 616
>Should I increase the limit of the memory assigned to mapserver? If so,
>could you give me some tips to do so?
>Any help to fix that problem would be appreciated.
>Thanks in advance.
>regards,
>Marc-André
