Shapefile questions
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Oct 1 08:20:37 EDT 2004
Sandeep Bashyal wrote:
> Hello,
> I have the following questions about shapefiles and mapserver:
> 1. Does Mapserver support "merged" polygons in shapefiles? E.g. arcview
> allows you to merge two or more NON-ADJACENT polygons, such that they are
> treated as a single shape and point to the same rows in the attribute
> table. I was wondering if mapserver supports such shapefiles with merged
> non-adjacent polygons.
Yes, this should not be a problem.
> 2. Is there a way to assign shapeindex for shapes in a layer from one of
> the fields in the attribute table (like in the mapfile or by dnamically
> adding a layer with phpmapscript)? I have a layer with over 4000 polygons
> whose attribute ID's do not correspond to the shapeindex returned from
> query results. I need the attribute ID's to link to a external database
> and display results.
You can access and attribute in a query and in fact I think you can do a
join of any attribute in a query result with and external database. Read
up on JOIN in the mapfile reference.
> Any advice on an easy way to write shapeindexes into a field in the
> attribute table would also be helpful.
> Thanks in advance.
> Sandeep Bashyal
> National GIS Officer
> Humanitarian Assistance Information System (HAIS)
> United Nations (NEP/01/008)
> UN House, Pulchowk
> G.P.O. Box 107
> Kathmandu, Nepal
> Tel: (+977) 01 5543957
> (+977) 01 5554304
> Cell:(+977) 9841270854
> Fax: (+977) 01 5528059
> mailto:gis at undphais.org.np
> mailto:sandeep at earthmapping.com
> http://www.undp.org.np
