Map wrap around??
Jerl Simpson
jerl.simpso at GMAIL.COM
Fri Oct 1 06:14:09 PDT 2004
Thanks for the link to the wiki.
I was hoping there was a directive I could give, it's no big deal
really. We have worked out a fix for this from the client side. I am
running a WMS server and we are using it to create rastered tiles of
the world. Then we browse those images via our web interface.
I appreciate the assistance.
Jerl
On Thu, 30 Sep 2004 15:58:56 -0400, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Jerl Simpson wrote:
> > Hi guys,
> > I am wonding if there is a way to get the map to wrap back around.
> > I have looked through documentation, and I have either completely
> > missed what I need, or didn't realize it was what I needed.
> > The problem I have now, is when I get to the "edge" of the map, it
> > just keeps going off into nowhere land. Is there a way to join up the
> > edges? This way if I want to pan across the Pacific and follow a
> > specific route, I can.
> Jerl,
> There is some discussion of this in the wiki in:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WorldMappingIssues
> There are many challenges with mapping over the antimeridian. If you can
> provide details of the projection you are mapping in, the projection of
> the data, type type of data (lines, raster) and the behaviour you are
> seeing we might be able to give some specific advice.
> I am keen on seeing global mapping work better in MapServer but it gets
> very sticky.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
