Editing shape files...or altering output.
Jerl Simpson
jerl.simpso at GMAIL.COM
Fri Oct 1 12:44:46 EDT 2004
Thanks, I'll look into Perl for this.
It looks like one of the perl dBase modules might help me out here too.
On Fri, 01 Oct 2004 11:08:36 -0400, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> You can do this in Perl using Geo::ShapeFile or Geo::Shapelib which
> might be the easiest way to do this. Your plan below is exactly how to
> do it, but Perl might be easier to write if you are familiar with it.
> I am not aware of any generic utilities that do this.
> -Steve W.
> Jerl Simpson wrote:
> > Hello,
> > I'm having a display issue that I need to work out. I am wondering
> > the best way to go about it. Here's the issue.
> > I have an ESRI shape file with US roads. In this file, the US
> > highways are listed as, "United States Highway 400". When you have a
> > lot of those on the map, it gets very messy. I would like to replace
> > "United States Highway 400" with "US 400" or even "US Hwy 400".
> > Is it best to change the .dbf file? Or can I do this on the fly?
> > I have no idea how to do this on the fly, but here are my thoughts on
> > the dbf file.
> > Use shapelib to open and read the dbf file, read in the values,
> > compare, change if needed, then spit out to a new dbf file.
> > Currently I would work at writing something to do this, after much
> > reading of the documentation.
> > Has anyone done this before? I suspect there might be a utility to do
> > just this type of thing.
> > Thanks in advance,
> > Jerl
