Editing shape files...or altering output.
Gregory S. Williamson
gsw at GLOBEXPLORER.COM
Fri Oct 1 17:25:18 EDT 2004
Agreed !
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at SWOODBRIDGE.COM]
Sent: Fri 10/1/2004 2:10 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Cc:
Subject: Re: [UMN_MAPSERVER-USERS] Editing shape files...or altering output.
Yes, this would be great, send it to me. Why not post it to the wiki!
-Steve
Jerl Simpson wrote:
> Hello,
> I don't know if anyone is interested, but I have written a Perl script
> to perform the function I was looking for earlier.
> If you like, I can send it to you, it's also very short, so I could
> post the code to the list if requested.
> It works like:
> dbfreplace.pl dbfile field "search string" "replace string"
> Let me know if you are interested in such a thing.
> Jerl
> On Fri, 1 Oct 2004 11:46:07 -0500, Jerl Simpson <jerl.simpso at gmail.com> wrote:
>>I notice in the shapelib library, there are example programs to add
>>records to the dbf file (dbfadd) I believe.
>>That might help you out.
>>Jerl
>>On Fri, 1 Oct 2004 11:52:41 -0400, MapServer List
>><mms at gnetconsulting.com> wrote:
>>>Hello list:
>>>I need to do something similar, except I need to add a record to
>>>the DBF and save it, using PHP/MapScript. Would I use the same
>>>steps? Or would it be easier to do it in a DBF editor of some sort?
>>>My platform is Linux 9/PHP/MapServer 4.2.1. Thanks.
>>>Joel
>>>----- Original Message -----
>>>From: "Stephen Woodbridge" <woodbri at SWOODBRIDGE.COM>
>>>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>>>Sent: Friday, October 01, 2004 11:08 AM
>>>>You can do this in Perl using Geo::ShapeFile or Geo::Shapelib which
>>>>might be the easiest way to do this. Your plan below is exactly how to
>>>>do it, but Perl might be easier to write if you are familiar with it.
>>>>I am not aware of any generic utilities that do this.
>>>>-Steve W.
>>>>Jerl Simpson wrote:
>>>>>Hello,
>>>>>I'm having a display issue that I need to work out. I am wondering
>>>>>the best way to go about it. Here's the issue.
>>>>>I have an ESRI shape file with US roads. In this file, the US
>>>>>highways are listed as, "United States Highway 400". When you have a
>>>>>lot of those on the map, it gets very messy. I would like to replace
>>>>>"United States Highway 400" with "US 400" or even "US Hwy 400".
>>>>>Is it best to change the .dbf file? Or can I do this on the fly?
>>>>>I have no idea how to do this on the fly, but here are my thoughts on
>>>>>the dbf file.
>>>>>Use shapelib to open and read the dbf file, read in the values,
>>>>>compare, change if needed, then spit out to a new dbf file.
>>>>>Currently I would work at writing something to do this, after much
>>>>>reading of the documentation.
>>>>>Has anyone done this before? I suspect there might be a utility to do
>>>>>just this type of thing.
>>>>>Thanks in advance,
>>>>>Jerl
