gdalindex question {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Oct 5 05:55:22 EDT 2004
What is in the location column in the dbf file? If it is a relative
path to the raszters then it should start from the directory of the map
file not the directory of the tile index.
Bye
Zoltan
On Mon, 4 Oct 2004, Dylan Beaudette wrote:
> Ed-
> Thanks for the quick reply!
> The mapserver output looks a litte funny because I am displaying the tile
> index as a polygon layer, so that I know that it actually exists, and is
> projected corectly. The labels do look like strange file names, but they are
> indeed correct...
> when i attempt to access the rasters individually:
> DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
> ...it works fine:
> http://169.237.35.250/~dylan/temp/tile_index_with_1_raster.jpg
> ...but the rasters are not loaded via the TILEINDEX method.
> here is the updated layer definition (thanks for the OFFSITE idea!!)
> ----------------snip------------------
> LAYER
> NAME "DOQQ_index"
> TYPE RASTER
> TILEINDEX "imagery/doqq/tiled/doqq_index.shp"
> TILEITEM "Location"
> #DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
> STATUS DEFAULT
> #ignore black pixels (treat as transparent)
> OFFSITE 0 0 0
> #render the rest of the pixel values!
> CLASS
> NAME "DOQQ"
> END
> END
> ...still no success with the rasters this way...
> any ideas?
> thanks again!
> Dylan
> On Monday 04 October 2004 11:37 am, Ed McNierney wrote:
> > Dylan -
> > Thanks for asking a well-documented question!
> > Your MapServer output looks like you're using the tile index layer as a
> > POLYGON layer, and doesn't seem to match up with the map file fragment you
> > post (i.e. there's no TYPE POLYGON layer with labels there). The filenames
> > that are appearing as labels look a little funny - are you sure those are
> > the correct filenames?
> > Also, you're causing all black pixels to be displayed as white, which won't
> > "remove" them. You may want to use the OFFSITE statement to cause black
> > pixels to be transparent, letting overlapped data show through.
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com
> > At 02:18 PM 10/4/2004, Dylan Beaudette wrote:
> > >Greetings!
> > >I have a pile of DOQQ images that i would like to use with my map, and
> > > wanted to use gdalindex to setup an efficient way for these images to be
> > > loaded.
> > >note that everything is in the same projection.
> > >after running:
> > >gdaltindex doqq_index.shp *.tiff
> > >i am left with a shapfile with entries for all of the images.... seems ok.
> > >...looking at the output in QGIS:
> > >http://169.237.35.250/~dylan/temp/gdalindex_problems.jpg
> > >...all seems fine (except for a few mssing images)
> > >however mapserver is not rendering the tiff files based on the index:
> > >http://169.237.35.250/~dylan/temp/tile_index.png
> > >here is my layer defs in my map file:
> > >----------------------------snip----------------------------
> > >LAYER
> > > NAME "DOQQ_index"
> > > TYPE RASTER
> > > TILEITEM "Location"
> > > STATUS DEFAULT
> > > #remove the black (no_data) pixels!
> > > CLASSITEM "[pixel]"
> > > CLASS
> > > EXPRESSION ([pixel] == 0 )
> > > COLOR 255 255 255
> > > END
> > > CLASS
> > > NAME "DOQQ"
> > > END
> > >END
> > >any ideas>?
> > >thanks in advance!!
> > >Dylan Beaudette
> > >Soil Science Grad Group
> > >University of California at Davis
