Adding an Event Theme/Layer
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Oct 5 17:25:10 EDT 2004
Bryon,
Here are some functions that might help you acheive what you want.
This code was taken from the php mapscript workshop at the Mapserver
user meeting (http://www.omsug.ca/osgis2004/proceedings.html).
Hope it helps.
Later,
* CreateLayer()
function CreateLayer($szDataName)
$oMap = $GLOBALS["goMap"];
//create layer and set members
$oLayer = ms_newLayerObj($oMap);
$oLayer->set("name", "canada_cities");
$oLayer->set("status", MS_ON);
$oLayer->set("data", $szDataName);
$oLayer->set("type", MS_LAYER_POINT);
$oLayer->setMetaData("DESCRIPTION", "New Cities Layer");
//projection is latlong
$oLayer->setProjection("init=epsg:4326");
$oLayer->set("labelitem", "NAME");
$oLayer->set("classitem", "CAPITAL");
//Country capital
//create class
$oClass = ms_newClassObj($oLayer);
$oClass->set("name", "Capital");
$oClass->setexpression("/1/");
//create style
$oStyle = ms_newStyleObj($oClass);
$oStyle->set("symbol", 2);
$oStyle->set("size", 8);
$oStyle->color->setRGB(255, 0, 0);
//set label object
$oClass->label->set("font", "fritqat-italic");
$oClass->label->set("type", MS_TRUETYPE);
$oClass->label->set("size", 8);
$oClass->label->color->setRGB(255, 0 , 0);
$oClass->label->set("position", MS_AUTO);
$oClass->label->set("partials", MS_FALSE);
//provincial capitals
$oClass->set("name", "Provincial Capital");
$oClass->setexpression("/2|3/");
$oStyle->set("symbol", 7);
$oStyle->set("size", 6);
$oStyle->color->setRGB(0, 0, 0);
//set label object
$oClass->label->set("font", "fritqat");
$oClass->label->color->setRGB(0, 0 , 0);
* AddDynamicLayer()
function AddDynamicLayer()
//Creating the shapefiles
$szFileName = $oMap->web->imagepath . uniqid("");
$oShapFile = ms_newShapeFileObj($szFileName, MS_SHP_POINT);
//create a new DBF attached with few attributes
$hDbf = dbase_create($szFileName.".dbf",
array(array("POP_RANGE", "N", 5, 0),
array("NAME", "C", 50, 0),
array("CAPITAL", "N", 5, 0)));
if (!$hDbf)
return;
//open the original dbf file
$szOrginalDbfName = "../data/canada_cities.dbf";
$hOrigDbf = dbase_open($szOrginalDbfName, 0);
if (!$hOrigDbf)
return;
$nRecords = dbase_numrecords($hOrigDbf);
for ($i=1; $i<=$nRecords; $i++)
//retreive field attributes
$aRecord = dbase_get_record_with_names($hOrigDbf, $i);
$dfLat = floatval($aRecord["LAT"]);
$dfLong = floatval($aRecord["LONG"]);
$nPopRange = intval($aRecord["POP_RANGE"]);
$szName = strval($aRecord["NAME"]);
$nCapital = intval($aRecord["CAPITAL"]);
//create a point for each record and add it to the shapefile
$oShp = ms_newShapeObj(MS_SHP_POINT);
$oLine = ms_newLineObj();
$oLine->addXY($dfLong, $dfLat);
$oShp->add( $oLine );
$oShapFile->addShape($oShp);
//add a record to the DBF
$aAttValues[0] = $nPopRange;
$aAttValues[1] = $szName;
$aAttValues[2] = $nCapital;
dbase_add_record($hDbf, $aAttValues);
$oShp->free();
dbase_close($hOrigDbf);
dbase_close($hDbf);
$oShapFile->free();
//Add a new layer in the map
CreateLayer($szFileName);
Bryon wrote:
> Question:
> As an ArcView user, I am used to being able to integrate what is called an
> event theme into a map view. An event theme is nothing more than a
> database with x and y attribute fields. The application sees these fields
> and maps the points. My question is is there a way to map a database
> using PHP Mapscript to create a Layer? My databases are generally in
> dBase format.
> Does anybody have any suggestions or examples?
> Sincerely,
> Bryon
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
