overlaping geotiff white area problem
Ed McNierney
ed at TOPOZONE.COM
Wed Oct 6 09:53:43 EDT 2004
Joerg -
You should open the new geotiffs in a graphics program that will let you read pixel values, and make sure that those pixels really have a RGB (or palette) value of 255 255 255. They may be "almost white" but OFFSITE requires an exact match.
- Ed
----- Original Message -----
To: Ed McNierney <ed at TOPOZONE.COM>
Sent: Wed, 6 Oct 2004 09:53:42 -0400
Subject: Re: [UMN_MAPSERVER-USERS] overlaping geotiff white area problem
> I already had OFFSITE, offset was a mistake.
> I reprojected the file with globalmapper, by switiching the projection
> from utm to geographic, datum:wgs84 and planar units:arc degrees.
> joerg
> Ed McNierney wrote:
> > Joerg -
> > The map file statement you want is OFFSITE, not OFFSET. If that doesn't work,
> tell us how you reprojected the files.
> > - Ed
> > Ed McNierney
> > TopoZone.com
> > From: joerg p <superbla3000 at GMX.NET>
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Sent: Wed, 6 Oct 2004 09:40:07 -0400
> > Subject: [UMN_MAPSERVER-USERS] overlaping geotiff white area problem
> >>hello,
> >>I reprojected two utm geotiffs to geo latlong geotiffs. The geotiffs are
> >>overlapping and now, reprojected, they have curved sides.
> >>But now each geotiff is surrounded by a white area, and i can't set it
> >>transparent with offset 255 255 255.
> >>So I have several white areas on my map. What should I do?
> >>Joerg
