tile and overview
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Wed Oct 6 13:21:09 EDT 2004
Hi --
try the command gdal_merge.py:
Usage: gdal_merge.py [-o out_filename] [-of out_format] [-co NAME=VALUE]*
[-ps pixelsize_x pixelsize_y] [-separate] [-v] [-pct]
[-ul_lr ulx uly lrx lry] [-n nodata_value] [-init value]
input_files
note that you have to compile gdal with python support for this to work.
Cheers!
Dylan
On Wednesday 06 October 2004 09:58 am, joerg p wrote:
> hello,
> I downloaded several overlapping europe etm+ mosaics, reprojected them
> to geo. Each file is around 1.2 GB. For better performance I know I have
> to tile them and build overviews.
> To tile and remove the overlapping, i would like to first combine all
> images and then to tile them.
> It's gonna be a really huge file during this process, around 18 GB, does
> this work?
> Could someone give me an example of this gdal combine command? I can't
> find it.
> How many overview steps should I build, is there a rule of thumb?
> thanks
> joerg
