[geos-devel] GEOS and Mapserver
Sean Gillies
sgillies at FRII.COM
Thu Oct 7 15:55:49 EDT 2004
Steve,
There already exists, for mapscript users, a SWIG interface to the
GEOS library. It's in the GEOS CVS. I think this is what programmers
should use rather than processing directives, which are only really
needed for the CGI program.
Sean
On Oct 7, 2004, at 12:27 PM, Steve Lime wrote:
> I've got a skeletal setup in MapServer now. Nothing functional just a
> setup of how this will work. Basically I propose extending the standard
> shapeObj to contain a GEOS geometry. Then I have to write the code to
> go
> between GEOS geometries and shapeObj's. The wrappers for the GEOS
> functionality then become really easy. You'll see things like
> msGEOSBufferShape and so on. You'll never see the GEOS geometry and
> will
> deal with shapeObj's. That way you can draw or use those features
> easily
> with existing MapServer code. I also plan to make use of the PROCESSING
> block as a mechanism to trigger processing. For example you might do
> something like:
> PROCESSING
> BUFFER 500
> END
> Which would trigger all features to be buffered before being released
> to MapServer or MapScript. MapScript would then gain a whole bunch of
> geospatial analysis methods attached to shapeObjs. That's what I'm
> planning anyways. Now just to find the time to write the converters.
> WKT
> will likely be too slow for this purpose.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
>>>> Godwinl at AGR.GC.CA 10/7/2004 12:29:04 PM >>>
> I've cross-posted this to various lists, so I'm sorry to those who are
> getting duplicates.
> I'd like to beef up my Mapserver applications with some geoprocessing
> functionality - buffers at present, other functions will follow. For
> now I am playing with PostGIS and having great sucess, IF my features
> are all stored in the database.
> What I'd like to be able to do though, is take a feature from WMS
> getFeatureInfo or WFS and be able to buffer that. As a test of this,
> I
> took the GML from a getFeatureInfo request and parsed it manually to
> be
> a WKT string. Then used PostGIS to run the buffer. Apart from slight
> precision differences, it appeared to be close to what PostGIS would
> have done with it's own feature (the WMS request was done against the
> same feature through MapServer).
> Now that I confirmed this is all possible, what I am missing is that
> I'd
> like to be able to
> a.. do the conversion from GML to WKT with some script/library
> b.. do this with a GML stream
> c.. ultimately do this without PostGIS database dependancy.
> I figure that GEOS can do the geometry format conversions, is this
> right?
> Has anyone written a library for linux/windows that will let me talk
> to
> it with PHP?
> I'm prodding these lists in hopes of finding out what else is going on
> out there in this area. It would be fabulous if this was all built
> into
> Mapserver, but from what I can tell, it's just a thought right now.
> Thanks!!
> Liz Godwin
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
