symbols changing color
John Bolster
jb at NUCOMP.COM
Sat Oct 9 19:25:37 EDT 2004
Hi all,
I defined a gif image as an interstate shield used in an annotation layer.
Now when I zoom in and out the color of the shields change on the output
map. The bulk of each shield should be pure blue, yet it becomes purple
sometimes and a light blue other times. They vary when I change the line
color of the underlying interstate line layer and also when I turn on and
off other layers (county lines and place polygons). Below are how my symbol
and annotation layer are defined. I can't see how mapserver is changing the
color of the gif--any suggestions on how I can get it to stay the same color
at all scales?
MapServer version 4.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
Thanks in advance,
John Bolster
SYMBOL
NAME 'int'
TYPE pixmap
IMAGE "./intsh.gif"
END
LAYER
NAME intlabels
GROUP "hwy"
TYPE annotation
STATUS off
DATA nhpn
PROJECTION proj=latlong END
CLASSITEM 'type'
LABELITEM 'num'
LABELMAXSCALE 4000000
CLASS
EXPRESSION "I"
COLOR 0 0 0
SYMBOL "int"
LABEL
SIZE tiny
POSITION CC
BUFFER 2
MINDISTANCE 200
COLOR 255 255 255
END
END
END
