Guess this Projection
Nick Dabner
dabner at OPTUSNET.COM.AU
Sun Oct 10 03:47:01 EDT 2004
Used libgeo to make a .tfw file of the raster. Very strange output:
2.5390625000
0.0000000000
0.0000000000
-2.5390625000
2478259.8695312501
4427159.8914062502
Could the results be random. I cannot recognise the format, and proj4
returns a bus error. This raster is a citymap of central Melbourne,
Australia at around 137E -40S WGS84.
ND
On 06/10/2004, at 8:29 PM, Nick Dabner wrote:
> Thanks for your help Peter. I misquoted the zone - it is actually 53,
> and I adjusted your parameters to suit. No luck unfortunately. The tiff
> is sourced straight of the Melways (eg Ausways / Sydways) CD.
> As I said, I can provide the sample file to a worthy challenger ;-)
> Nick
> On 06/10/2004, at 3:15 PM, Peter Bayley wrote:
>> Nick,
>> The AMG66 Zone 55 Projection needs to be placed in the LAYER object in
>> the
>> map file:
>> Taking the proj4text vales from the spatial_ref_sys table in postgis,
>> you
>> can construct the
>> projection of the layer as:
>> LAYER
>> PROJECTION
>> "proj=utm"
>> "zone=55"
>> "ellps=aust_SA"
>> "south"
>> "units=m"
>> END
>> CONNECTIONTYPE OGR
>> CONNECTION "ADELBRIS.TIF"
>> TYPE RASTER
>> STATUS DEFAULT
>> UNITS METERS
>> END
>> The Projection in the LAYER should be the projection of its dataset.
>> By the
>> way, 20253 is Zone 53 not 55
>> The projection you want everything delivered in should be in the MAP
>> section
>> Regards
>> Peter Bayley
>> Sydney
>> Australia
>> ----- Original Message -----
>> From: "Nick Dabner" <dabner at OPTUSNET.COM.AU>
>> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Sent: Wednesday, October 06, 2004 12:55 PM
>> Subject: [UMN_MAPSERVER-USERS] Guess this Projection
>>> Hello all,
>>> Have one nasty little raster here that is apparently in AMG66 Zone 55
>>> (epsg:20253), according to Mapinfo. I cannot get it to display in
>>> mapserver unless I warp it, but doing so results in an image that is
>>> incorrectly registered and skewed (also out by 1500km or so). I am
>>> trying to output in WGS84 / GDA94 in line with my vectors. Gdalinfo
>>> output is shown below. I can provide a copy by email if anyone would
>>> care to take a closer look. This has been causing me problems for
>>> months now. Mapfile is below. Any help greatly appreciated, Nick
>>> Driver: GTiff/GeoTIFF
>>> Size is 4809, 4075
>>> Coordinate System is:
>>> PROJCS["unnamed",
>>> GEOGCS["unnamed",
>>> DATUM["unknown",
>>> SPHEROID["unretrievable - using
>>> WGS84",6378137,298.257223563]],
>>> PRIMEM["Greenwich",0],
>>> UNIT[,0.0174532925199433],
>>> AUTHORITY["EPSG","0"]],
>>> UNIT["unknown",1],
>>> Origin = (1857716.251568,5544261.870844)
>>> Pixel Size = (317.52333125,-317.52333125)
>>> Metadata:
>>> TIFFTAG_IMAGEDESCRIPTION=
>>> TIFFTAG_DATETIME=2004:01:05 22:39:05
>>> TIFFTAG_XRESOLUTION=300
>>> TIFFTAG_YRESOLUTION=300
>>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>>> Corner Coordinates:
>>> Upper Left ( 1857716.252, 5544261.871)
>>> (106439300d44'382252089395.85"E,317662805d42'1142461300788.73"N)
>>> Lower Left ( 1857716.252, 4250354.296)
>>> (106439300d44'382252089395.85"E,243527362d35'876173328429.93"N)
>>> Upper Right ( 3384685.952, 5544261.871) (193928220d
>>> 0'700079669251.66"E,317662805d42'1142461300788.73"N)
>>> Lower Right ( 3384685.952, 4250354.296) (193928220d
>>> 0'700079669251.66"E,243527362d35'876173328429.93"N)
>>> Center ( 2621201.102, 4897308.083)
>>> (150183760d22'541165879323.76"E,280595084d 9'1009317314579.33"N)
>>> Band 1 Block=4809x1 Type=Byte, ColorInterp=Palette
>>> The mapfile looks roughly like this (originally based on the itasca
>>> demo):
>>> # Start of map file
>>> NAME DEMO
>>> STATUS ON
>>> SIZE 600 600
>>> EXTENT 144.5 -37.5 145.5 -38
>>> UNITS KILOMETERS
>>> SHAPEPATH "data"
>>> IMAGECOLOR 255 255 255
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> WEB
>>> HEADER demo_header.html
>>> TEMPLATE demo.html
>>> FOOTER demo_footer.html
>>> IMAGEPATH "set in demo_init.html"
>>> IMAGEURL "set in demo_init.html"
>>> END
>>> QUERYMAP
>>> SIZE 200 200
>>> STATUS ON
>>> STYLE HILITE
>>> COLOR 255 0 0
>>> END
>>> SYMBOL
>>> NAME 'circle'
>>> TYPE ELLIPSE
>>> POINTS 1 1 END
>>> FILLED TRUE
>>> END
>>> LAYER
>>> PROJECTION
>>> "init=epsg:4202" # Also Zone 53 "20253"
>>> END
>>> CONNECTIONTYPE OGR
>>> TYPE RASTER
>>> STATUS DEFAULT
>>> UNITS METERS
>>> END
>>> END # Map File
