editing shapefiles, changing them
Tyler Mitchell
tylermitchell at SHAW.CA
Mon Oct 11 11:37:59 EDT 2004
Mike,
It sounds like you have set the wrong 'units' during digitizing? And you want
to 'scale' the data to fit a wider part of the earth -- is that right?
I have some ideas of how you could do this by setting your PROJECTION options
for that layer using the right UNITS. It might not be possible though. Can
you make your file available for others to have a peek at?
Tyler
On October 11, 2004 03:06 am, Michal Krupička wrote:
> Hi all,
> I am not sure, if this conference is the right place for my question.
> The problem: I have shapefile with some objects, but they were made in bad
> resolution. It was my fault during digitalization. But now when the
> shapefile is created i need to change its resolution. I need to raise all
> object five times and save it back to shapefile. This problem appears in
> scalebar, where the wrong values are now.
> Thanks Mike
