Projection - how to specify?
Tyler Mitchell
tylermitchell at SHAW.CA
Mon Oct 11 14:53:22 EDT 2004
I'm not a projections guru, but I suspect it will look something like the
following. Note that I'm just throwing this together to give you an idea -
and to give others something to correct :)
Hope it helps you!
Tyler
PROJECTION
"proj=lcc" # Projection name
"lat_0=-37" # Latitude origin
"lon_0=145" # Central meridian
"lat_1=-36"
"lat_2=-38"
"x_0=2500000"
"y_0=4500000"
"unit=meters"
END
On October 10, 2004 10:58 pm, Nick Dabner wrote:
> How would this VicGrid/AGD66 projection be specified in mapserver? It
> is an Australian projection focused around the state of Victoria.
> Lambert Conformal Conic
> Std Parallel 1: 36S
> Std Parallel 2: 38S
> Central Meridian: 145E
> Origin: 37S
> Unit: Metre
> False Easting: 2,500,000 m
> False Northing: 4,500,000 m
> Many thanks in advance.
> Nick Dabner
