building Mapserver on Gentoo: with-proj doesn't see files
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Tue Oct 12 14:25:00 EDT 2004
Jeff Kowalczyk wrote:
> I need information on the expectation of the with-proj argument:
> ./configure --with-proj=/usr/lib
> configure: checking whether we should include PROJ.4 support......
> configure: error: "Could not find projects.h or libproj.a/libproj.so in
> /usr/lib."
> Same result for /usr/bin, /usr/share/proj, etc. Its almost like the make
> file doesn't see any of those files, but they are present. Any
> suggestions?
You should use "--with-proj=/usr". Just "--with-proj" would do as well
since your proj appears to be installed in the default system
directories and MapServer's configure will look there by default.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
