State Plane Virginia South Projection Question
Newland Agbenowosi
newland at VT.EDU
Wed Oct 13 04:19:16 EDT 2004
You can use one of the following for state plane south
the necessary parameters can be found the epsg file that comes with the
installation of proj4.
see an example attached file.
PROJECTION
"proj=lcc"
"lat_1=36.333333333"
"lat_2=-78.500000000"
"lat_0=37.966666667"
"lon_0=36.766666667"
"x_0=3500000.000"
"y_0=1000000.000"
"ellps=GRS80"
"datum=NAD83"
"units=m"
END
or
PROJECTION
"init=epsg:32147"
END
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Dave Williams
Sent: Tuesday, October 12, 2004 4:32 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] State Plane Virginia South Projection
Question
Hello Group.
Is there a known and available resource that explains the specifics for
applying US State Plane projections to the MapServer .map file?
I have consulted the proj 4 documentation as well as any examples I can
find on the web and have not had too much luck. Any help, examples or
insight is greatly appreciated.
Thanks!
Dave B. Williams
www.dbwilliams.com
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041013/30327d21/epsg.obj
