jBox zoom problem
Yannick Doiron
yannick.doiron at CIPANB.CA
Fri Oct 15 15:50:19 EDT 2004
Hi List,
This my first message to the forum. I've installed the jBox applet by
following the jBox How-To found in the Mapserver documentation page. Now i
am in the "Fine Tunning with Javascript" section like turning the Box
dragging on and off. With my little knowledge in Javascript, i tried to
figure it out but with no success. I am getting an error with Internet
Explorer when i am using the code bellow "...Failure to evaluate
reset_handler('jBox',-1.0,-1.0,-1.0,-1.0);".
Can someone help me complete or change what I have so fare to have jBox
working correctly?
I am using mapserver 4.0 as CGI on winxp pro
Here's the codes I am using right now.
<script language="JavaScript">
//********the function i am trying to figure out********
if(document.zoomdir[1].checked){
document.jBox.dragoff();
document.jBox.boxon();
else{
document.jBox.boxoff();
//******jBox functions*********
function setbox_handler(name, minx, miny, maxx, maxy) {
document.mapserv.imgbox.value = minx + " " + miny + " " +
maxx + " " + maxy;
document.mapserv.imgxy.value = minx + " " + miny;
document.mapserv.submit();
function seterror_handler(message) {
alert(message);
</script>
....here's the jBox applet section...
<td colspan="2">
<applet
codebase="/java/jBox"
archive="jBoxPNG.jar,png.jar"
code="jBoxPNG.class"
width="570"
height="570"
name="jBox"
MAYSCRIPT>
<param name="image" value="http://[host][img]">
</applet>
</td>
...here's the radio buttons for the zooms...
<input type="radio" name="mode" value="query"> <b>Query </b>
<input type="radio" name="mode" value="browse" checked><b>Browse</b><br><p>
<input type=radio name=zoomdir value=0 onClick="document.jBox.dragon();"
[zoomdir_0_check]> Pan <p>
<input type=radio name=zoomdir value=1 [zoomdir_1_check]> Zoom In <p>
<input type=radio name=zoomdir value=-1 onClick="document.jBox.boxoff();"
[zoomdir_-1_check]> Zoom Out <p>
<input type=text name=zoomsize size=1 value=2> Zoom size
...and here's the hidden input type option value....
<input type="hidden" name="imgxy" value="299.5 299.5">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value="[program]">
<input type="hidden" name="map_web_imagepath" value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
<input type="hidden" name="imgbox" value="-1 -1 -1 -1">
Any help will ben greatly appreciate, I am turning around with this for a
while..
Yannick Doiron
Technicien en géomatique
CIPA inc.
1040, rue du Parc, pièce 1
Paquetville (Nouveau-Brunswick) E8R 1J7
Téléphone: (506) 764-1030 Télécopieur: (506) 764-1039
www.cipanb.ca
