Win32 binaries with SDE, anyone ?
ANDY CANFIELD
andy_canfield at HOTMAIL.COM
Fri Oct 15 20:01:58 EDT 2004
I know you guys are working on the fcgi for win32 but if they want something
sooner there is another option. DM Solutions can do custom builds for people
at their hourly support rate. I sat down and worked it out once. I could get
all kinds of custom stuff put into the build at their rate for much less
than if you factor in all the time it would take me to get it all set up to
compile. ( At the time I was just trying to get more layers into mapserver )
I believe they produce nightly WIN32 binaries so I wonder if it would just
be faster fot these folks to get a custom compiled binary? We have found the
rate more than reasonable and it gives us more time to actually build
applications against the binaries rather than using that same time trying to
get something to compile just to begin testing against. That way they could
have a solution up and going and tested and then in the future they could
get the fcgi binaries from you guys. Just a thought anyway.
>From: Paul Ramsey <pramsey at REFRACTIONS.NET>
>Reply-To: Paul Ramsey <pramsey at REFRACTIONS.NET>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Win32 binaries with SDE, anyone ?
>Date: Fri, 15 Oct 2004 07:36:59 -0700
>Mike, we are currently scraping the last of the bugs off the CVS
>version with support for fcgi. Once we have a working copy, we will
>distribute it for you and Lorna to you.
>Paul
>On 14-Oct-04, at 10:06 PM, Mike Davis wrote:
>>I am in the same position... We have an existing Mapserver site
>>running mainly from shapefiles. Moving to SDE based data is a must
>>for our organization to continue use of Mapserver. Unfortunately I
>>haven't been able to get authorization to install the tools necessary
>>to build a custom install including SDE support. If someone does
>>happen to have a win32 binary available for testing I would appreciate
>>it.
>>On a related note... does anyone know anything about the image support
>>in SDE 9.0? I would love to be able to access the same imagery set I
>>am serving up to ESRI users. I imagine there might be some speed
>>gains to be had as well.
>>Thanks in advance
>>Mike Davis
>>GIS Specialist
>>Fort Richardson, Ak
>>On Tue, 12 Oct 2004 22:32:46 -0500, Lorna <lorna_grimm at yahoo.com.au>
>>wrote:
>>>Hi
>>>I'm hoping someone can offer a copy of their latest win32 Mapserv
>>>binary
>>>compiled with SDE support.
>>>I have SDE 8.3 client software installed, I just dont have the tools
>>>to
>>>compile Mapserver under windows. I want to use Mapserver to server
>>>spatial
>>>data, instead of ARCIMS but if I cant get MapServer with SDE enabled
>>>I'll
>>>have to scrap this idea, which is a real shame !
>>>Thanks, Lorna
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
