gdalwarp with alpha band masking
    Jan Hartmann
    j.l.h.hartmann at UVA.NL
    Thu Oct 21 04:22:52 PDT 2004
Thanks Chris (and Frank). This is exacly the scenario for my historical
cadastral mapping project. Thanks for sharing!
Jan
Jan Hartmann
Department of Geography
University of Amsterdam
Chris Hodgson wrote:
 > Hope this was worth the read for some of you :-)
> I'd like to share a fun project I've been working on lately with
> Mapserver and GDAL, for the interest and potential benefit of others.
> BEWARE - Long post follows...
> My task was to take a somewhat disorganized collection of orthophotos in
> tiff format and setup a WMS to serve a mosaic of these photos for use as
> a backdrop to support operators conflating road networks. This at first
> seemed like it would be an exceptionally simple task, just get all the
> images, run gdaltindex to make a tileindex for mapserver, setup the
> mapfile, and it's done. However, there were several problems that needed
> to be overcome in particular the quantity of data, and the mixed
> projections of the images.
> There is 2-4TB of orthophotos to work with. We were able to reduce this
> somewhat because we only need orthophotos that overlap with both of the
> road networks we are conflating, but it is still more data than we want
> to deal with. We decided to solve this by compressing to JPEG-2000
> format - at a rate of 10:1, I cannot tell the difference between the
> original image and the compressed one. We are using the Kakadu library
> and gdal_translate to do this conversion, however, since we are using a
> lossy compression we needed to do all of the image processing before the
> compression in order to minimize image degradation.
> Next problem - not all of the images were in the same projection, most
> were in UTM, but I wanted them all in BC Albers. gdalwarp solves the
> reprojection problem quite nicely, however, the output images have empty
> "collars" around the edges where data is missing due to the reprojected
> image not filling the entire bounding box of the image in the new
> projection. One way around this would be to put all the tiles together
> beforehand with something like gdal_merge.py, then reproject them, then
> slice them up into new tiles afterward. However, due to the quantity of
> the data, this was not an ideal solution. In fact, you don't even need
> to put them all together, all you need to build one tile is itself and
> its eight neighbors - however, this requires far more processing than
> our final solution for effectively the same result. The final solution
> was to ask Frank to add an alpha band mask to the output of gdalwarp, so
> that instead of a black collar, there is transparency. With an
> additional change to mapserver to automatically use this alpha band
> channel (it already did for colour images, just not for greyscale
> images), a tiled layer of these reprojected images looks as though it
> has been mosaicked together - in fact, mapserver is basically doing the
> mosaicking on the fly. Note that the reprojected images all overlap
> eachother, but the overlapping areas are mostly transparent.
> A couple things which aren't addressed in this solution are color
> balance/histogram equalization, and fixing seams with morphing/warping.
> The histogram equalization might be easily solved with imageMagik, but
> I'm not sure. The seaming is trickier stuff, but I suspect OSSIM might
> be able to do this sort of thing. In fact, OSSIM might be able to do all
> of this, but I didn't want try to learn a whole new piece of software on
> a rush-project.
> In the end, here is my processing stream:
> - use imageMagik to convert to grayscale if not already so:
> convert -colorspace GRAY $in_file $out_file
> - use gdalwarp to convert to the right projection, and add transparency
> to existing and resulting nodata areas:
> gdalwarp -dstalpha -srcnodata 0 -co 'ALPHA=YES' -s_srs 'epsg:26910'
> -t_srs 'epsg:42102' -rc $in_file $out_file
> - use gdal_translate to convert the reprojected file to jpeg 2000 using
> kakadu - options are from the kakadu examples site, they seem to work
> well but then I haven't found options that don't work well:
> gdal_translate -of JP2KAK -co 'Clayers=20' -co 'Clevels=8' -co
> 'Corder=RPCL'
>                       -co 'Cprecincts={256,256},{256,256},{128,128}'
> -co 'ORGgen_plt=yes'
>                       -co 'ORGtparts=R' -co 'Cblk={32,32}' -co
> 'Creversible=no' -co 'quality=10' $in_file out_file
> - build a tileindex of all of the files for mapserver:
> gdaltindex tiles.shp *.jp2
> - setup my layer in mapserver:
>  LAYER
>    NAME "orthophoto"
>    METADATA
>      "wms_title" "orthophoto"
>    END
>    STATUS ON
>    TILEINDEX "tiles.shp"
>    TILEITEM "Location"
>    TYPE RASTER
>    PROJECTION
>      "init=epsg:42102"
>    END
>  END
> Right now I have 1389 jp2 tiles totalling 45.5GB, and mapserver can
> render a screen-size view of all of them in about 15 seconds - the
> machine is an Athlon 64 3500+ with 2GB RAM and a pair of 7200RPM 250GB
> SATA drives in software RAID 1 on Fedora Core 2 x86_64. The render time
> seems to be pretty proportional down to around 1 second... ie. if you
> look at half of it, it takes 7 seconds, a fifteenth of it takes 1
> second, and basically any zoom level smaller than that takes about 1
> second or less. JP2K files (especially with the options I specified
> above) are created with multi-resolution and spatial indexing in mind,
> so every jp2 file effectively is internally tiled and has many overview
> layers, at little to no extra cost in file size - this contributes
> greatly to the speed, I'm sure.
> I'm still processing data right now, but once I'm all done I will use
> gdal_merge.py to create an overview layer. It will be slightly degraded
> since I will have to base it on the lossily-compressed jp2s, but the
> quality of the overview isn't important. With an overview layer in place
> (or maybe two), I expect to be able to provide sub-second response time
> to render any bounding box at screen resolution.
> Thanks to Frank Warmerdam for adding the new features into GDAL and
> Mapserver that made this all possible.
> Sorry, but I can't share the final result due to licensing agreements on
> the orthophotos.
> Chris Hodgson
> Refractions Research Inc.
More information about the MapServer-users
