SWF output from Mapserver WMS
Joshua Lieberman
josh at OKLIEB.NET
Thu Oct 21 09:25:02 EDT 2004
Bart,
Thanks for your information.
It does appear as if the output of the swf file is somehow disabled, as
the mime type is set correctly in the headers, the flash browser
plug-in loads, but no content arrives. I didn't find anything explicit
in a quick perusal of the WMS code about this, but will also try the
developer's list for more information.
Josh
On Oct 20, 2004, at 2:08 PM, Bart van den Eijnden wrote:
> Hi Josh,
> there were some changes done for this by DMSG in June 2004.
> See:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=781
> Don't know what the current status is though.
> Best regards,
> Bart
> On Wed, 20 Oct 2004 09:19:13 -0400, Joshua Lieberman <josh at OKLIEB.NET>
> wrote:
>> I am running Mapserver 4.2.0 on RedHat 9 and have linked in the Ming
>> (0.3beta1) library (OUTPUT=SWF). The data sources are PostGIS 0.8.2
>> layers.
>> The flash output format shows up in GetCapabilities; A nice map is
>> returned for jpg or png formatsl but the swf output always seems to be
>> blank. This is the same for (OUTPUT_MOVIE=SINGLE) or
>> (OUTPUT_MOVIE=MULTIPLE).
>> Does the flash output work with WMS ?
>> Thanks,
>> Josh
>> Joshua Lieberman
>> josh at oklieb.net
>> tel (857) 919-1071
>> fax (775) 514-6621
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Joshua Lieberman, Ph.D.
geospatial architect
josh at oklieb.net
tel (857) 919-1071
fax (775) 514-6621
