query on oraclespatial using OGR/OCI
Fernando S.
simon at INF.UNIVALI.BR
Thu Oct 21 12:30:35 EDT 2004
Hi Pierre,
The query functions can be possible in the next version of the
Oracle Spatial support. I implemented these functions here in my
computer and I believe that this functions will be include in the next
version of native support.
I don't know how the OGR implement the query function but this
problem appear when you use functions that use the primary filter like
SDO_FILTER.
Here the problem disappear when I recreate the indexes without
SDO_LEVEL. Another point is the tolerance, you can try set a small
value for Tolerance like 0.00001.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
bluecarto at free.fr wrote:
>First question : how can you query oracle layers if you don't use OGR ? I mean
>the function are not implemented for oraclespatial connectiontype.
>I had already try you suggestion (ommitting the SDO_LEVEL parameter). That could
>be a good idea, but, sadly, it doesn't give any better result.
>I'm using Oracle 10g on Debian or Oracle 9.2 on RedHat.
>In my sample the result given seem to be the first record in the table.
>Regards
>Pierre
>Selon FERNANDO SIMON <simon at inf.univali.br>:
>>Hi Pierre,
>> I don't use OGR but your problem can be with the spatial index. I saw
>>this
>>problem with the 10G version.
>> In the 10G version the Oracle don't recommend use SDO_LEVEL when you
>>create
>>the spatial index. In my tests problems appears when I set the SDO_LEVEL, the
>>result doesn't correspond whant I expected.
>> I don't know if the problem occur with others Oracle Spatial versions.
>>But
>>you can try with or without SDO_LEVEL.
>>Quoting Pierre GIRAUD <bluecarto at FREE.FR>:
>>> I'm still having difficulties to use mapserver queries on a oracle layer.
>>> Before I report a bug, I would like someone to test the following SQL
>>>statement
>>>and mapfile, and agree that something is going wrong, or tell me I am
>>>missing
>>>something obvious.
>>> Thx
>>> Pierre GIRAUD
>>> camptocamp.com
>>>---------SQL statement--------------
>>>DROP table mytable;
>>>CREATE TABLE MYTABLE (
>>> GID VARCHAR(20),
>>> geometry MDSYS.SDO_GEOMETRY);
>>>insert into MYTABLE (GID,GEOMETRY) values (
>>> '1',
>>> mdsys.sdo_geometry(
>>> '2003',
>>> null,
>>> null,
>>> mdsys.sdo_elem_info_array(1,1003,1),
>>> mdsys.sdo_ordinate_array(1,1, 1,4, 4,4, 4,1, 1,1))
>>> '2',
>>> mdsys.sdo_geometry(
>>> '2003',
>>> null,
>>> null,
>>> mdsys.sdo_ordinate_array(6,1, 6,4, 9,4, 9,1, 6,1))
>>> '3',
>>> mdsys.sdo_geometry(
>>> '2003',
>>> null,
>>> null,
>>> mdsys.sdo_ordinate_array(1,6, 1,9, 9,9, 9,6, 1,6))
>>>delete from user_sdo_geom_metadata where table_name like 'MYTABLE';
>>>insert into user_sdo_geom_metadata (table_name,column_name,diminfo,srid)
>>>values ('MYTABLE','GEOMETRY',
>>>mdsys.SDO_DIM_ARRAY(mdsys.SDO_DIM_ELEMENT('X', 0, 10, 0.1),
>>>mdsys.SDO_DIM_ELEMENT('Y', 0, 10, 0.1)),
>>>NULL);
>>>drop index q_mytable;
>>>create index Q_MYTABLE on MYTABLE(GEOMETRY) indextype is
>>>MDSYS.spatial_index
>>>parameters ('SDO_LEVEL=6');
>>>---------mapfile---------------
>>>NAME DEMO
>>>STATUS ON
>>>SIZE 500 300
>>>EXTENT 0 0 10 10
>>>IMAGECOLOR 255 255 255
>>>WEB
>>> IMAGEPATH "/var/www/images/"
>>> IMAGEURL "images/"
>>>END
>>>LAYER
>>> NAME squares
>>> TYPE POLYGON
>>> STATUS ON
>>># CONNECTIONTYPE oraclespatial
>>># CONNECTION "scott/tiger at orcl"
>>> CONNECTION "OCI:scott/tiger at orcl"
>>> CONNECTIONTYPE OGR
>>># DATA "select * from mytable"
>>> DATA "mytable"
>>> TEMPLATE "ttt"
>>> CLASS
>>> SIZE 10
>>> COLOR 255 255 255
>>> OUTLINECOLOR 200 200 200
>>> END
>>>END
>>>END
>>>Selon bluecarto at free.fr:
>>>> Hello,
>>>>Following the good advices of Frank Warmerdam, I improve in using oracle
>>>>spatial
>>>>data with spatial indexes. For now, I know that I should not use sql
>>>>statements
>>>>in the mapfile but queries directly to the table :
>>>> DATA "my_table"
>>>>instead of
>>>> DATA "select * from my_table"
>>>>Both return the same images. Shapes are well drawn, and labeling is
>>>correct.
>>>>But the first (more performant) statement doesn't give good results to a
>>>>query.
>>>>The data returned doesn't correspond to what is expected. And no shape is
>>>>highlighted.
>>>>Do someone using Oracle have same problems ?
>>>>Pierre GIRAUD
>>>>camptocamp.com
>>Este e-mail foi enviado pelo webmail do curso de
>> Ciência da Computação - UNIVALI
