Compile-Error 4.3-nightly on SuSE
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Sun Oct 24 12:37:31 EDT 2004
Some more info on this issue.
I ran into this (hence bug 909). Note that you'll have to recompile
everything on your system which was compiled with the second libiconv,
i.e. I ended up having to recompile Apache, etc. with the default
libiconv.
Cheers
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Daniel Morissette
> Sent: Sunday, 24 October, 2004 12:32
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Compile-Error 4.3-nightly on SuSE
> Benjamin Thelen wrote:
> > Hi,
> > I successfully built nightly builds from 24.09.04, 04.10.04 and
> > 21.10.04 on FreeBSD 4.10. But on SuSE 9.0 building fails with the
> > error message below. Building 4.2.5 on SuSE is successful.
> > As I thought, the error could have something to do with an old
> > libiconv (1.9.1), I installed libiconv-1.9.2, but it didn't help it.
> This sounds very much like bug 909:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
The problem would be that your system comes with the iconv functions as
part of glibc and when you install a second libiconv on your system you
end up with duplicate symbols. I'd suggest removing the libiconv-1.9.2
that you installed and trying configure/make again.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
