More GD errors
Sean Gillies
sgillies at FRII.COM
Mon Oct 25 12:04:20 EDT 2004
On Oct 25, 2004, at 9:18 AM, Norman Barker wrote:
> Hi,
> I have switched boxes to a clean install of Red Hat FC2 to compile
> MapServer (nightly build),
> FC2 ships with the 2 series version of GD as required mapserver but the
> configure script still fails
> to pick it up even when I use --with-gd=/usr/local
> Has anyone got a (fool-proof!) set of instructions for compiling
> MapServer? This GD error
> is a hurdle I can't get over!
> Many thanks,
> Norman Barker
Norman,
If you provide more details, I'll try to help. Your message gives us
little to
go on. Specifically: MapServer version, the output of the configure
script,
and your actual configure command.
I'm using a FC2-based distribution (KRUD) and it comes with GD 1.8.4 in
/usr/lib.
Are you sure you have a GD 2? If so, where are the libraries and
include files
found?
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
