More GD errors
Norman Barker
normanb at COMSINE.CO.UK
Mon Oct 25 13:35:00 EDT 2004
Sean Gillies wrote:
> On Oct 25, 2004, at 10:54 AM, Norman Barker wrote:
>> Sean Gillies wrote:
>>> On Oct 25, 2004, at 9:18 AM, Norman Barker wrote:
>>>> Hi,
>>>> I have switched boxes to a clean install of Red Hat FC2 to compile
>>>> MapServer (nightly build),
>>>> FC2 ships with the 2 series version of GD as required mapserver but
>>>> the
>>>> configure script still fails
>>>> to pick it up even when I use --with-gd=/usr/local
>>>> Has anyone got a (fool-proof!) set of instructions for compiling
>>>> MapServer? This GD error
>>>> is a hurdle I can't get over!
>>>> Many thanks,
>>>> Norman Barker
>>> Norman,
>>> If you provide more details, I'll try to help. Your message gives us
>>> little to
>>> go on. Specifically: MapServer version, the output of the configure
>>> script,
>>> and your actual configure command.
>>> I'm using a FC2-based distribution (KRUD) and it comes with GD 1.8.4
>>> in
>>> /usr/lib.
>>> Are you sure you have a GD 2? If so, where are the libraries and
>>> include files
>>> found?
>>> Sean
>>> Sean Gillies
>>> sgillies at frii dot com
>>> http://users.frii.com/sgillies
>> I have to boxes one that is running Red Hat 9 and the other FC 2, the
>> errors are the same so I will describe both
>> I building the nightly snapshot of MapServer so that I can use the WCS
>> functionality.
>> I have a version of GD in /usr/lib, and version 2.x of GD in
>> usr/local/lib
>> so running
>> ./configure --with-wcs --with-gd=/usr/local --with-proj=/usr/bin
>> --with-png=/usr/lib --with-wmsclient
>> --with-curl-config=/usr/bin/curl-config --with-wfsc
>> lient --with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config
>> --with-wfs
>> (as kindly given by Newland Agbenowosi)
>> gives the following error
>> "Could not find gd.h or libgd.a/libgd.so in /usr/local. Make sure GD
>> 2.0.12 or higher is compiled before calling configure."
>> Any help would be greatly appreciated.
>> Norman
> Looking in our configure script, I'm not convinced that GD_LIBDIR is
> being
> properly set to /usr/local/lib so that AC_CHECK_LIB is checking that
> particular GD library for the necessary version. Steve, can you
> confirm?
> On my system, I've removed the older 1.8.4 GD to prevent this kind of
> conflict, but we should probably work to improve our configure script.
> Not everyone has the option to clear out GD from /usr/lib.
> Norman, in the meanwhile, try setting the environment variable
> LD_LIBRARY_PATH=/usr/local/lib before you configure. This should insure
> that configure looks in the proper GD library for version checking.
> Sean
> Sean Gillies
Thanks for the help, I set LD_LIBRARY_PATH=/usr/local/lib as suggested
but I still get the error
are there any other work arounds you can think of?
Thanks,
Norman
