"Missing ImageLength filed" problem when requesting Tiff via
Frank Warmerdam
warmerdam at POBOX.COM
Mon Oct 25 13:39:35 EDT 2004
Henry Han wrote:
> Hi,
> I am trying to serve image via map server WMS. JPG, GIF, PNG all work
> well. But when I try "fomat=image/tiff", it does allow me to download
> and save the image, but I just can not open it. With GDAL gdalinfo to
> check the tiff image, it tells me following info.
> Error 1: MissingRequired: d:\temp\mapserv.tif: TIFF directory is missing
> requried "ImageLength" field
> GDALOpen failed -1
Henry,
This generally means your TIFF file is corrupt. I would suggest you run
the tiffinfo command on your file (and perhaps tiffdump too) and then
take the issue to the TIFF mailing list (or to me privately).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
