Label Join {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Oct 26 15:21:51 EDT 2004
You can join a dbf file to shape (which has a dbf too).
But I've used it in queries.
You must define a JOIN block in the layer definition.
LAYER
NAME base
DATA ... # use your data instead of ...
TYPE ...
CLASS
TEMPLATE ...
END
HEADER ...
FOOTER ...
JOIN # one-to-one join
NAME joined
TABLE the_name_of_dbf
FROM join_column_in_base
TO join_column_in_joined
END
END
After it you can refer to the joined columns joined_columnName.
It works me in the query template.
Bye
Zoltan
On Tue, 26 Oct 2004, Sylvain Beorchia wrote:
> Hi list,
> Is there any way to make a JOIN between 2 DBF for labelling ?
> I read somewhere that it was impoosible, but that was 2 years ago..so what about now ?
> Thanks.
> Sylvain.
