queryByRect
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Oct 28 15:33:52 EDT 2004
N Zhou wrote:
> $ms = ms_newMapObj($map);
> $aRect = ms_newRectObj();
> $aRect->setextent(minx, miny, maxx, maxy);//the extent of georeference
> $selectLayer = $ms->getLayerByName(layer_name);
> $q_success = $selectLayer->queryByRect($aRect);
> if ($q_success == MS_SUCCESS) {
> $numResult = $selectedLayer->getNumResults();
> $results = $selectLayer->getResult(0);//get the first query result
> The queryByRect is success. But I got an error message of the
> getNumResults():
> Fatal error: Call to a member function on a non-object in myscript.php
> on line 26
The error tells you that $selectedLayer is not an object and you cannot
call a method on it... that's because the $selectedLayer variable is not
set... it's a typo, it should be $selectLayer.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
