Creation of layer object in Python Maps cript
Sean Gillies
sgillies at FRII.COM
Thu Oct 28 17:38:59 EDT 2004
On Oct 28, 2004, at 12:07 PM, Ryan, Adam wrote:
>> -----Original Message-----
>> From: Sean Gillies [mailto:sgillies at frii.com]
>> Sent: Thursday, October 28, 2004 10:15 AM
>> To: Ryan, Adam
>> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: Creation of layer object in Python Maps cript
>>>> From: Bill Hudspeth [mailto:bhudspeth at EDAC.UNM.EDU]
>>>> Sent: Thursday, October 28, 2004 8:56 AM
>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>> Subject: [UMN_MAPSERVER-USERS] Creation of layer object in Python
>>>> Mapscript
>>>> Hello,
>>>> I want to write new map layers on the fly in my scripting. I have
>>>> found the reference to "new layerObj()" in the
>> documentation, but am
>>>> unsure of how to write the exact syntax. Haven't had any luck with
>>>> "new_layer=layerObj(mapObj)".
>>>> Any help greatly appreciated.
>>>> Bill
>>> Hi Bill,
>>> I'm working on the same thing 'bout now.
>>> For me, this crashes Python:
>>> layerO = mapscript.layerObj(mapO)
>>> layerO = mapscript.layerObj()
>>> mapO.insertLayer(layerO)
>>> But this works OK:
>>> However, if I then check layerO.index, I get 1634300513.
>> That's a lot
>>> of
>>> layers.
>>> If I check mapO.getLayersDrawingOrder(), I get _30fc8200_p_int. Is
>>> this a
>>> typemap issue?
>>> If I try layerO.promote() or layerO.demote(), I'm told those methods
>>> don't
>>> exist.
>>> I'm still trying to figure this one out. Let me know if
>> you make any
>>> headway.
>>> Adam
>> Which version of mapserver are y'all using?
>> Sean
> OK,
> The new layer is appended so it's index is mapO.numlayers-1 even
> though
> it's index parameter is foobar.
> And although promote and demote don't seem to be in mapscript.py, we
> can use
> mapO.moveLayerDown(index), so that's cool...
> Adam
Adam,
Promote and demote are gone for good. It's better design to use
methods of the container.
In the next beta I'll make sure that the index of a new layer is
initialized to something sensible. Meanwhile, I cannot reproduce
your problem with creating a new layerObj instance with a mapObj
argument. I have a test case for this in the unit tests and it
always passes. Please report the error that occurs and I'll work
on it.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
