In version 4.2.5 Label buffer in GRID doesn't work
Giorgio Plazzotta
giorgio.plazzotta at SARASRICERCHE.IT
Fri Oct 29 04:01:09 EDT 2004
MAPSERVER-USERS Digest - 27 Oct 2004 to 28 Oct 2004 (#2004-96)After the reinstallation of Mapserver 4.2.5 I noticed a malfunctioning in the behaviour of the GRID layers in my mapfile.
The proble is that the labels on the border of the GRIDS are shown twice. This is because of the BUFFER parameter. Mapserver shows both the label at the normal position (on the grid line) and also the buffered label at a certain distance. I partially solv ed the problem eliminating the BUFFER option in the label section. In the previously installed Mapserver version (4.0) the same mapfile worked well and the buffer option acted as it was expected putting the laber at 4 or 5 pixel distance from the line.
I include the code of the grid layer in the mapfile:
Giorgio Plazzotta
Assemini - Italy
LAYER
NAME "Reticolo UTM/WGS84"
GROUP "Localizzazione geografica"
STATUS OFF
MINSCALE 1
MAXSCALE 2000000
TYPE LINE
CLASS
COLOR 128 128 128
LABEL
FONT fritqat
TYPE truetype
POSITION AUTO
#BUFFER 5
SIZE 7
COLOR 128 128 128
PARTIALS FALSE
END
END
PROJECTION
"init=epsg:23033"
"ellps=WGS84"
"zone=32"
"north"
"no_defs"
END
GRID
LABELFORMAT "%.0f"
MAXARCS 5
MAXSUBDIVIDE 2
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041029/e66b4210/attachment.html
