gd makefile
Swaminathan, Gayathri
gayathri at OU.EDU
Wed Sep 1 12:29:33 EDT 2004
Hi:
Like Frank says it can be quite challenging to compile in windows....
I had to recompile regex...as mine got corrupt. I got a copy of the makefile from Ed...long time ago..Please find attached.
I do not think GD is your problems..it would rather be GDAL...
Seems like you have ODBC support enabled in your nmake.opt......Please follow Frank's recommendation
As there are no other errors apart from the ones related to regex and GDAL...I think..recompiling other libraries wont be necessary....
Thanks
Gayathri
> -----Original Message-----
> From: Jingyu Bai [mailto:baijingyu at HOTMAIL.COM]
> Sent: Wednesday, September 01, 2004 11:11 AM
> To: Swaminathan, Gayathri
> Subject: Re: gd makefile
> I also have a hard time now to compile the map server source
> code under windows using visual c++. I am wondering how you
> get it successed. Do you need to compile GD library and REGEX
> Libary as well as other used libraries too ? Would you mind
> to give me some tips to follow? Thanks
Type: application/octet-stream
Desc: Makefile.vc
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040901/161d0437/Makefile.obj
