[UMN_MAPSERVER-USERS] problem with postgis layer
    Skweda O'Bomsawin
    sobomsawin at KASSINI.COM
    Wed Sep  1 10:27:45 PDT 2004
Alberto,
It seems to be a projection issue.  Since you don't have a projection
section in your layer definition, make sure your data are in the same
projection system as your map file.  Otherwise, add a projection section to
your layer.  Also try to use FROM in small caps in your data sentence...
__________________
Skweda O'Bomsawin
Directeur géomatique
Kassini Systèmes Experts
771, Saint-Joseph Est
suite 320
Québec, QC, G1K 3C7
Tél: 418.652.0925
Fax: 418.653.7344
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Alberto Cavalli
Envoyé : 1 septembre 2004 11:45
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] problem with postgis layer
Hi dear I've a problem, I'm using mapserver but, when I try to see my page,
I can't see anithyng. I've putted all my shape in postgresql through
postgis.
This is the layer definition in my map file
LAYER
    NAME "Confine"
    STATUS DEFAULT
    DATA "the_geom FROM h887_c"
    TYPE POLYGON
    CONNECTIONTYPE POSTGIS
    CONNECTION "user=postgres PASSWORD=admin dbname=template1 host=localhost
port=5432"
    UNITS METERS
    SIZEUNITS PIXELS
    TOLERANCE 0
    TOLERANCEUNITS PIXELS
    TRANSPARENCY 25
    CLASS
      NAME "confini"
      #TEMPLATE "false_query.html"
      STYLE
        COLOR 255 204 153
      END
    END
  END
I'm working on
apache 2.0.46
php 4.3.3
mapserver 4.0
win 2000 professional
 bye
alberto
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.745 / Virus Database: 497 - Release Date: 2004-08-27
Outgoing mail is certified Virus Free.
More information about the MapServer-users
