Query shapes in certain extent
Lowell Filak
lfilak at MEDINACO.ORG
Wed Sep 1 23:04:15 EDT 2004
The following message was sent by G-Net Consulting
<joelf at GNETCONSULTING.COM> on Wed, 1 Sep 2004 13:31:58 -0400.
> Lowell/List:
> I updated my code, as you suggested. The results are coming out
> now, but seem to be a page behind. An example:
> I have states that have points in each. So, say you choose
> Florida. It should have 247 points. If you then choose Alaska,
> it now says 247 (which was Florida from before). If you go
> to another state (that should have 0, it finds 7).
> I'm also assuming the index pulled is the one in sensors.shx? I
> really need to pull the ID from sensors.dbf.
> I'm attaching my code and map file segment. Any/all suggestions
> would be appreciated.
> Thanks!
> MAP File ========================
> LAYER
> NAME "sensors"
> STATUS ON
> DATA "./sensors"
> TYPE POINT
> CLASSITEM "ID"
> SYMBOLSCALE 10
> LABELITEM "ID"
> LABELCACHE ON
> POSTLABELCACHE TRUE
> TEMPLATE "sensors.html"
> METADATA
> "DESCRIPTION" "GMF Sensors "
> "RESULT_FIELDS" "ID"
> END
> CLASS
> NAME "Sensors"
> STYLE
> SYMBOL 4
> COLOR 0 255 0
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> SIZE 3
> MINSIZE 3
> MAXSIZE 100
> END
> END
> END
> PHP Code: ========================
> // get our sensor layer
> $myLayer = $gmfMap->getLayerByName("sensors");
> $myLayer->set("status", 1);
> // create a rectangle object to search in and set the extent (from
> querystring params)
> $rectObj = ms_newRectObj();
> $rectObj->setextent($_GET["minx"], $_GET["miny"], $_GET["maxx"],
> $_GET["maxy"]);
> // query the points in the chosen space
> @$myLayer->queryByRect($rectObj);
> // find out how many results we found
> $shpCount = $myLayer->GetNumResults();
> // loop through our results, and process accordingly
> if ($shpCount) {
> for ($i = 0; $i < $shpCount; $i++) {
> // get our result
> $layerIndex = $myLayer->getResult($i);
> $arrShapes[] = $layerIndex->shapeindex;
> Joel
> ----- Original Message -----
> From: "Lowell Filak" <lfilak at medinaco.org>
> To: "G-Net Consulting" <joelf at GNETCONSULTING.COM>;
> <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Wednesday, September 01, 2004 9:20 AM
> Subject: Re: [UMN_MAPSERVER-USERS] Query shapes in certain extent
> > <joelf at GNETCONSULTING.COM> on Tue, 31 Aug 2004 14:50:11 -0400.
> > > Hello list:
> > > What is the best way to access the shapes and locations of
> > > points marked within a given map? I have several hundred
> > > points I need to find that are displayed from a given layer.
> > > What's the best way to accomplish this?
> > > I currently have a layer that has over 5,000 points marked
> > > through the US. As they drill down, I plan to use JavaScript
> > > to display information about each one. In the dbf file, I have
> > > an ID that corresponds to an ID in a MySQL table. I just
> > > to get the ID"s of just the one displayed inside the chosen
> > > extent.
> > > I'm using PHP 4.3.3 with MapScript 4.2.1 on Redhat 9.
> > > Thanks in advance.
> > > Joel
> > Joel;
> > If you create a rectObj using the specified extent you can use
> > layer->queryByRect to query the point(s) into the layer resultcache and
> > then use layer->getResult & resultCacheMemberobj->shapeindex to retrieve
> > the shapeindex for each of the resulting points.
> > If your id in the mysql database corresponds to the shapeindex your all
> > set. If not then you will need to use an xbase module to pull the nth
> > (shapeindex) record from the dbf file to obtain the id that links to the
> > id in the mysql table.
> > Lowell
Joel;
If the results look as if they are one page behind is it because the
get/put that is sent is a "page behind"?
You are correct that the index pulled is not from the dbf. But it is the
corresponding record number in the dbf.
HTH
Lowell
