Need help to compile mapserver-4.2.2 under windows
Swaminathan, Gayathri
gayathri at OU.EDU
Thu Sep 2 09:15:45 EDT 2004
Hello:
This is probably because of your LDFLAGS in Makefile.vc.....
I had to change,
LDFLAGS = /NODEFAULTLIB:libcd /DEBUG
To this,
LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
HTH
Gayathri
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jingyu Bai
> Sent: Wednesday, September 01, 2004 12:44 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Need help to compile
> Gayathri:
> I searched the archive and found many anwsers from you to
> help the user like me. I really appreciate your help. I
> managed to have a Regex.obj and change map server nmake.opt
> to enable ODBC_LIB , now I can go a step further but still
> have problem to compile it. I now get : ... ....
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _localtime already
> defined in LIBC.lib(localtim.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _abort already
> defined in LIBC.lib (abort.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _strcspn already
> defined in LIBC.lib(strcspn.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: _isalnum already
> defined in LIBC.lib(_ctype.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __stricmp already
> defined in LIBCMTD.lib(stricmp.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __strnicmp already
> defined in LIBCMTD.lib(strnicmp.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __strdup already
> defined in LIBC.lib(strdup.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __stat already
> defined in LIBCMTD.lib(stat.obj); second definition ignored
> MSVCRT.lib(MSVCRT.dll) : warning LNK4006: __unlink already
> defined in LIBCMTD.lib(unlink.obj); second definition ignored
> Creating library mapserver_i.lib and object mapserver_i.exp
> LINK : warning LNK4098: defaultlib "LIBCMTD" conflicts
> with use of other libs; use /NODEFAULTLIB:library LINK :
> warning LNK4098: defaultlib "MSVCRT" conflicts with use of
> other libs; use /NODEFAULTLIB:library libmap.dll : fatal
> error LNK1169: one or more multiply defined symbols found
> NMAKE : fatal error U1077: 'link' : return code '0x491' Stop.
> It seems I got a lots of MSVCRT.lib(MSVCRT.dll) warning too
> but not fatal though.
