Colors, PNGs
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Sep 6 09:41:47 EDT 2004
This is a know problem see
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=306
I posted a work-a-round that worked for me, you might get it to work for
you. There is also a PROCESSING directive that allows you to combine
colors that are within "n" color cells of one another into a single
color. this works well with tiffs and potentially level other color
slots open for you other layers.
-Steve W.
Titus von der Malsburg wrote:
> On Mon, Sep 06, 2004 at 01:55:01PM +0200, Niels van Dijk wrote:
>>I guess your otho's are TIFF's?
> Right, TIFFs + worldfiles
>>If so try this:
>>Compile with:
>>--WITHOUT-TIFF
>>It has somethig to do with the sequence in which tiff support is loaded.
> Because TIFF support is in libtiff _and_ gdal?
> I did recompile mapserv with --without-tiff yielding
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=JPEG INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> But the problem continues to exist :-(
> Thanks anyway,
> Titus
