Aquire x/y coordinates from rectangle object
G-Net Consulting
joelf at GNETCONSULTING.COM
Tue Sep 7 10:43:03 EDT 2004
Lowell:
Thanks for the reply.
I actually got it working another way. I pulled the lat/long vars from
the DBF and displayed them that way, after I found a snippet in the
old mailing list archives. But I think I'll try it this way, too, as it
seems more elegant.
Thanks again for the help.
Joel
----- Original Message -----
To: "G-Net Consulting" <joelf at GNETCONSULTING.COM>;
<MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, September 07, 2004 10:37 AM
Subject: Re: [UMN_MAPSERVER-USERS] Aquire x/y coordinates from rectangle
object
> The following message was sent by G-Net Consulting
> <joelf at GNETCONSULTING.COM> on Sat, 4 Sep 2004 01:14:23 -0400.
>> Hello List:
>> I'm looking for a snippet of code to grab the X/Y coordinates
>> from a point in a shape file. I've pulled the shape data in
>> from the DBF (thanks to Lowell for that). Now I would like
>> to display the data in overLib with a mouseover.
>> So what is the best way to get the X/Y for each shape
>> in the chosen extent?
>> Thanks.
>> Joel
> Joel;
> You can:
> shapeObj = new shapeObj(type_point)
> use the shapeindex from resultCacheMemberObj with
> layer->getShape(shapeObj, 0, shapeindex)
> pointObj=shapeObj->get(0)
> pointObj->{x} & pointObj->{y}
> The doc (at least swigmapscript) needs to be clearer on this.
> Lowell
