Map colors in PHP/Mapscript 4
G-Net Consulting
joelf at GNETCONSULTING.COM
Mon Sep 13 11:40:15 EDT 2004
Hello list:
Probably a simple mistake on my part, but I cannot get the proper
colors to display on my map. I'm wondering what I'm doing wrong.
I assume the .map setup would be fine, or do I need to specify
this info programmatically in PHP?
I want the image to have a white background. The map is the US
with Alaska, Hawaii, and Puerto Rico. I want the states to be a
light brown, with the county and state boundaries black.
Currently, the state outlines are black, the counties are brown, and
everything else (all backgrounds) are white. The sensors (last layer)
display fine.
Any help would be appreciated. Thanks.
.MAP File
MAP
NAME "GMF"
STATUS ON
EXTENT -179.133392 17.674692 179.788208 71.398048
SIZE 600 450
SHAPEPATH "./data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 255 255 255
# UNITS METERS
# SCALE 165582
# include our web data
WEB
# MINSCALE 2000000
# MAXSCALE 50000000
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
# include our querymap data
QUERYMAP
STATUS ON
COLOR 255 0 0
STYLE HILITE
END
# add our legend
LEGEND
STATUS ON
# IMAGECOLOR 255 255 255
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE "ttt"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
# OFFSET 0 BUFFER
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
# specify the format to save the image as
OUTPUTFORMAT
NAME "PNG"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT OFF
END
OUTPUTFORMAT
NAME imagemap
MIMETYPE "text/html"
DRIVER imagemap
END
# begin our counties layer
LAYER
NAME "counties"
STATUS ON
DATA "./counties"
TYPE LINE
CLASSITEM "COUNTY"
SYMBOLSCALE 8
LABELITEM "COUNTY"
LABELCACHE ON
POSTLABELCACHE TRUE
TEMPLATE "counties.html"
METADATA
"DESCRIPTION" "US Counties "
"RESULT_FIELDS" "STATE"
END
CLASS
NAME "Counties"
STYLE
SYMBOL 8
COLOR 238 207 145
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 238 207 145
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
# begin our states layer
LAYER
NAME "states"
STATUS ON
DATA "./states"
TYPE LINE
CLASSITEM "STATE"
FILTERITEM "STATE"
SYMBOLSCALE 8
LABELITEM "STATE"
LABELCACHE ON
POSTLABELCACHE TRUE
TEMPLATE "states.html"
METADATA
"DESCRIPTION" "US States "
END
CLASS
NAME "States"
STYLE
SYMBOL 8
COLOR 0 0 0
OUTLINECOLOR 0 0 0
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
# begin our sensors layer
LAYER
NAME "sensors"
STATUS ON
DATA "./sensors"
TYPE POINT
CLASSITEM "ID"
SYMBOLSCALE 10
LABELITEM "ID"
LABELCACHE ON
POSTLABELCACHE TRUE
TEMPLATE "sensors.html"
METADATA
"DESCRIPTION" "GMF Sensors "
"RESULT_FIELDS" "ID"
END
CLASS
NAME "Sensors"
STYLE
SYMBOL 4
COLOR 0 255 0
OUTLINECOLOR 0 0 0
SIZE 3
MINSIZE 3
MAXSIZE 5
END
END
END
END
