javaMapscript compilation
Umberto Nicoletti
unicoletti at PROMETEO.IT
Tue Sep 14 06:07:38 EDT 2004
The Java interpreter needs to find (and load) the shared library that
contains the C code you are invoking through Java objects.
To do this you have two options:
1) put mapscript.so in a standard location (see /etc/ld.so.conf for you
systema defaults) (you might have to run ldconfig, but that's usually not
necessary)
2) set the env variable LD_LIBRARY_PATH to the directory containing
mapscript.so. You can do that from your bash shell typing:
export LD_LIBRARY_PATH=/path/to/mapscript.so
HTH,
Umberto
